Yes, it happened to me too.Lots of issues with subwoofer output.
After today’s update it doesn’t work anymore.
Tried to switch off and on but no signal.
Tried factory reset and it worked, but after a restart it vanished.
At the very least, this issue should be fixed by the next update.Tried it and it worked a while.
Please wiim support fix this.
I’m tired of uninstalling apps and factory reset
I thought the subwoofer output was something that was special, but now it’s a big issue.
Have you already tried plugging and unplugging the WiiM and SW power cables?This subwoofer issue is not resolved. Please help or I need to return this and buy a sonos
Unplugging the power cable for a couple of seconds should be all that is needed to make it work, worst case.Yes multiple times. So annoying. Will return. Thnks
A reboot from the WiiM Home app is the most simple thing I'd be trying first. Good point.Actually I think I had this issue yesterday. I checked the connections since I moved the Amp previously. After re-plugging all connection didn’t help I did an Amp restart via the Home App and the sub was back.
Maybe you should try to slide the level up in the app for the sub.It happens to me when I’m watching tv and the hdmi is used. Then it can take a time to get the subwoofer working. Maybe it’s an unstable timer delay for the sub signal? It’s something for the software developers to fix.
