That's my question of the Amp, can it do proper sub management?For me it's standmounts and sub(s) over big floorstanders any time, if proper sub management is available.
The exception might be bigger rooms where big floorstanders and sub(s) are probably the best solution.![]()
Does rc also include the sub?Room EQ will need the following
Testing of left, right and subwoofer independently
Delay/phase, levels, alignment of left, right and subwoofer independently
PEQ filters for left, right and subwoofer independently
So... it dependsFor me it's standmounts and sub(s) over big floorstanders any time, if proper sub management is available.
you find many answers here https://faq.wiimhome.com/support/so...ence-a-comprehensive-guide-to-room-correctionDoes rc also include the sub?
Thank you..i will read this info first.you find many answers here https://faq.wiimhome.com/support/so...ence-a-comprehensive-guide-to-room-correction
Then i have a question.you find many answers here https://faq.wiimhome.com/support/so...ence-a-comprehensive-guide-to-room-correction
Thanks i see it now.On the first screen, Welcome to Room Correction.
Top right, green cog icon.
Press it.
Thanks very much.I'm (very) far from even being a novice with room correction.
Frequency range - seems that generally room issues are in the low frequencies, hence the default of 4khz.
As for sub crossovers etc, well, I have (skim)read lots of posts on it, so best to search a bit or wait for someone else to answer!
Whatever you do, if you don't like the result you can repeat with different settings or turn it off completely. Try it and see.Thanks very much.
I find it difficult..i mean as I beginner in this matter i have no clue of what I'm doing and you don't want just play with a setting if you don't know what you are changing.
I have to read more before using RC ..
I will thanks very much.Whatever you do, if you don't like the result you can repeat with different settings or turn it off completely. Try it and see.
You might find the documentation for HouseCurve relevant to tuning helpful.I mean how can i now before the calibration what i have to choose here..?
Yes i see the explanation what it's for but what are the correct values? How can I know it?
Start off by leaving all the settings at default. Just choose a target curve. I choose flat but many prefer the others.I will thanks very much.
I will read some more on the matter before.
Because still have no idea what frequency I have to set...what do I have to look out for.
Then how can I set the gain,Q before when i dont have any clue how to set the correct values for it.
With RC calibration I assume there is no music playing?
So how will I know what Q or gain i have to choose?
Thanks very much..i will inform myself. I will read it..You might find the documentation for HouseCurve relevant to tuning helpful.
Thanks..Start off by leaving all the settings at default. Just choose a target curve. I choose flat but many prefer the others.
Yes.Thanks..
So the gain and Q also at default?
