slartibartfast
- Apr 18, 2024
No reply but the status is now "Being processed"Did they finally reply or not?
We don't know if calibration files will be added in the future. For now you could apply Room Correction in the WiiM app and check the results in REW.Quick question.. probably already answered by someone. Is it / will it be possible to apply a calibration file for my iMM-6c microphone in the app? Does this calibration file significantly affect the measurement? If so, and the file cannot be uploaded, is it better to use REW?
You can follow up by sending message by saying “what’s the status of being processed?” I got same like you then follow up with message and then got answer in 12 hours.No reply but the status is now "Being processed"
Not the other way around? Use REW with calibration file to do RC, and apply the results in Wiim app?We don't know if calibration files will be added in the future. For now you could apply Room Correction in the WiiM app and check the results in REW.
You can do it both ways but if you want to see how well the WiiM RC works use it for RC then use REW to measure the response of the system with the WiiM EQ enabled. Ideally it would follow your chosen target curve.Not the other way around? Use REW with calibration file to do RC, and apply the results in Wiim app?
Is rc on wiim on par with rew? I ask because I never use it.You can do it both ways but if you want to see how well the WiiM RC works use it for RC then use REW to measure the response of the system with the WiiM EQ enabled. Ideally it would follow your chosen target curve.
In a word no. To start WiiM at most relies on two short sweeps R-L rather than averaging multiple sweeps from multiple positions.Is rc on wiim on par with rew? I ask because I never use it.
Until it includes the subwoofer it is hard to tell.Is rc on wiim on par with rew? I ask because I never use it.
Just got a reply saying it will be fixed in the next version. Shame it couldn't have been fixed in the app version released today. It can't be a difficult fix as it was working correctly in the beta before they added the toggleYou can follow up by sending message by saying “what’s the status of being processed?” I got same like you then follow up with message and then got answer in 12 hours.
This will explain a little of my confusion hereJust got a reply saying it will be fixed in the next version. Shame it couldn't have been fixed in the app version released today. It can't be a difficult fix as it was working correctly in the beta before they added the toggle
No. This has been answered regularly on the forum...I am using android with MiniDSP UMIK-1 for room correction. Is there an option I can load calibration file of UMIK on the app?
Thanks, my bad I couldn't figure it out. Is it under consideration, will this be available in future versions?No. This has been answered regularly on the forum...
In your other post you were told it was your phone microphone.Can anyone help out, i did what the manual said but i have this peak near the treble region. Measured with my samsung with mic faced to the speakers.
My room is certainly not optimal and echoes a bit.
Thank i.a
1. How does it sound to you? Have you tried manually reducing the gain for that peak to see if it sounds better to you?Can anyone help out, i did what the manual said but i have this peak near the treble region. Measured with my samsung with mic faced to the speakers.
Thank i.a
Thank you, ill try that.1. How does it sound to you? Have you tried manually reducing the gain for that peak to see if it sounds better to you?
2. You’re normally advised to leave the range at 40hz-4khz - you seem to be trying to apply it to the full range. Try rerunning it with the reduced range and again see if you prefer how that sounds
