ChrisHamilton
- Nov 5, 2023
Hi harkpabst, TeamWiiM have that covered, even if not automatically.
Still, there's no way of correcting the direct sound and reflections independently. Also, corrections made at higher frequencies might be beneficial right in the MLP but are likely to turn into the opposite just a couple of inches away. A bit of care taken with speaker setup and toe-in is certainly rather more affective, as long as WAF doesn't get into the way. Non-symmetrical rooms/speaker placement is why I'm waiting for per-channel PEQ, though.
Preset your personal reference and the Auto-EQ uses this in its calculation. Like I have an 8dB loss at 8k. So compensate 8dB at 8k.What kind of preset? What level? What criteria? For what?
Just measure it… works great!
You guys are awesome.Hi harkpabst, Team
We are developing an auto-measurement feature for subwoofer latency, which will be integrated into our auto-calibration process. This enhancement aims to provide a more seamless audio setup experience with your subwoofer. We plan to release this feature for Beta testing by the end of July. Please stay tuned for updates!
Hi,Hi, perhaps someone can explain how room correction works. Correct me if I’m wrong but it is my understanding that the equalisation should be, to a first approximation, the mirror image of the measured curve, so that the peaks and troughs cancel each other to yield a smooth curve. If this is the case, why isn’t the trough at 50Hz cancelled out?
Wiimer from Japan are smart people.Hi,
I'm no expert, but perhaps you have either limited the gain to 10dB or less in the WiiM app, or the EQ cannot correct that dip.
If I am wrong, surely someone else can tell you the correct answer.
The gain was less than the 12db permitted, and I can manually increase the equalisation to further reduce the trough.Hi,
@Wiimer, the default on iOS rc was range 40 to 4khz. I did play on this by raising it to 20k and left gain and q on default. I’m not sure if it’s the mic on iPhone that’s incorrect or what but wiim just cut all the treble by sizable amount on flat. It still sound good but cutting treble with multiple frequency and 8 to 10db will make sound a bit dull. The default 40 to 4K sounds awesome.
Do you know if I can attach external mic on iPhone and works with rc?
I think the lower limit for the iphone's built-in mic is 60hz, right?
RC made my system sounds for the better. I’m normally the kind of person who like to bypass anything that might color the sound like tone bypass but after the correction even it’s was altered not bit perfect but my ear appreciates the changes of its sound character that I left it on. RC maybe coloring the sound that hard core audiophile would disagree that you should listen without altering the original sound or using tone control.I can't wait to try it myself.
Btw, would the accuracy be further improved if you set the range to something like 40 to 500hz?
In any case, I believe it is difficult to make a perfect correction with auto RC alone.
Someone said they could do that, but I don't think they can do a mic calibration yet.
