Subwoofer output at low volume intermittent. Gate / Threshold?
Yes Youtube
I tried 75 Hz on the same channel and, oddly enough, still no sound from the Sub. The cone is not moving at all.
Also, when I change the crossover from 120Hz ->250Hz, the 75Hz volume heard from the main speakers is the same, so it seems that the signal that should be going to the Sub is going to the main speakers.
Strange...
If anything, I am a clumsy goofy 😂
Appreciate the attempt to reproduce the problem I am facing.
To exacerbate the problem, turn the sub volume via the Wiim right down, and the volume on your wubwoofer right up and use a high crossover on the wiim. (has to be using the wiims crossover)
If this doesnt reproduce the issue I will have to investigate the possibility of a fault elsewhere. thanks.
