Sync subwoofer setting with EQ
whisen
I am using 2.1 channels in various configurations.
1. Speakers only
2. Crossovers
3. Crossover sub + Speaker Bass ouput
I am using EQ differently according to each configuration.
If I want to watch a movie while listening to music mainly in the 2 composition, change it to 3.
The problem is that I have to do a lot of manipulation when change to 3.
1.Eq Changes
2. Subwoofer level up
3. Turn on the main speaker bass output
I hope it will be changed together when I change EQ only.
Upvote 0
I don't understand that argument. You can of cause select any Preset manually and a Preset can set an input and an output, as it can now.
Then there is no problem.
I assumed that the preset 1 associated with the input would no longer be able to be pressed manually.
Your suggestion may be the easiest solution 😄
