Its 1A only so too less... Anyway. You are moving in to wrong directionAnyone tried it with a regular iPhone 5W supply?
iPhone power supplies are very clean and shown to improve other devices.
Actually… it may work. Because Apple devices have design margins and WiiM Pro use 1A or so.Its 1A only so too less... Anyway. You are moving in to wrong direction![]()
I have one from 2015 here , I can try when I got time , maybe its even better than the iPad charger from 2012 ?Anyone tried it with a regular iPhone 5W supply?
Actually lower for the pro: 440 mV during booting, even lower when playing music…the plus model is more power hungry.Actually… it may work. Because Apple devices have design margins and WiiM Pro use 1A or so.
Im sure there are some switching regulators inside the WiiM. I would also guess its probably 3,3 V. Every regulator have some dropout, and switching regulators have much less dropout and heat.Why is 5v very important?
I'm fairly confident that the SOC on all wiim devices don't operate at 5v.
Typically 3v3, so I'm similarly confident that any 5V input faces a voltage regulator on the wiim. I suspect this to be a switcher, does anyone know?
I'd be interested to know. It adds an interesting dimension to the PSU discussion.
Often sections within a SOC operate at different voltages too. Perhaps they could benefit from separate PSUs too?
That is a pity, it was such a nice idea. Do you have a plan b?Im sure there are some switching regulators inside the WiiM. I would also guess its probably 3,3 V. Every regulator have some dropout, and switching regulators have much less dropout and heat.
My lm317 powersupply is working without sound issues connected to the WiiM pro during tv watching for 2 hours. However, the linear regulator heatsink gets hot, to warm to touch . I also have some mechanical noise coming from the transformer .
The first plan is to find out If this regulator is better sounding than my iPad charger with the WiiM pro used as digital bridge, plan B after this is probably to try an ifipower x and maybe also a lt3086 board.That is a pity, it was such a nice idea. Do you have a plan b?
The Ifi PowerX has arrived, have it connected but no time to listen now, in a few days hopefully.
Looks like dithering added by the recording software. Next time try without it to get perfectly the same files.Made my own test for anyone interested. Wav 16/44 Stereo track snippet of Level42. Should show dynamics, leading edges, bass separation, vocal harshness/sibilance, space & spread of soundstage. These were recorded with HiFiMe optical digital interface direct from Wiim Optical out to computer USB, so only testing the digital side, not the internal DAC. The files were streamed to the Wiim via AlexaCast/Amazon Music from my Android tablet.
2 tracks, one using Wiim standard power supply, the other using Temple Audio Supercharger (below) which uses a bank of supercapacitors:
Drop box link:
DROPBOX
What is this track exactly?Dont think so:
