I have finally listened with Wiim Pro powered by the IFI Power X and comparing the IFI to the LPS (Linear Power Supply) as tested earlier in this post
this post , using my playlist on
Qobuz:
Wiim Pro PSUs test .
The description of the DAC/Amp and headphones etc. is in my profile.
First I tried the IFI in the last outlet of the power block:
Music played, but after approx. 2 minutes got a distorted crackling sound. After turning off, and on again the Wiim same thing happened.
Switched from Coax to optical connection between the Wiim and amp, no distorted sound at all. The problem was solved by turning the IFI 180⁰ in the outlet; using the Coax connection gave no issues anymore. So that shows that the IFI is sensitive to the correct polarity.
Note: I prefer using the Coax output because in my case it sounds better.
Now the listening could finally begin:
1. With IFI iPower X in the last outlet of power strip:
Not 100% happy, knowing it can sound better.
2. With the IFI in the 3rd outlet, which is normally used for the PSU to the Wiim: better than 1. Music sounds louder than with the LPS, with some tracks I prefer to set a lower volume. It sounds very clean, though I am a bit less emotionally involved in the music, maybe a bit of nervousness is added by the IFI. S-sounds are okay, but a bit less variety in them. Maybe there is a little bit less force in the sub lows. I feel less urge to listen to every track in the playlist completely. It sounds very good, yet I am still missing something.
Going back to the LPS powering the Wiim:
3. More subtleties, details and especially more natural. For example in the track by Kendji Girac and Soprano their different voices are easier to seperate. Emotions in the music are easier conveyed.
Because music sounds apparently a bit less loud, I can turn up the volume higher, yet without any listening fatigue.
These small but important improvements brought by the LPS, make me want to listen, not analytical but for pleasure.
With a warm sounding system you might prefer the IFI, however in my set I will keep using the LPS powering the Wiim Pro and enjoy the music... a lot.
