No, as I said, 3 different PSUs.Or maybe it was the same powersupply on all three files ?
(my question is for "musician"... )In all these cases single channel - left one if I remember correctly - was taken directly from the Pro Plus analog output, and converted into digital form using my ADC.
Source file is here:
Original2
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
your wiim pro in analog (really not good) or in digital to dac? I didn't understand...Ok -
onlyoneme , tell us which powersupplies were used with each file ?
I liked nr 1 as most musical but a little less dynamic, nr 3 as most dynamic but also slightly unmusical. Nr 2 was somewhere in between .Try to find Sbooster and Nirvana first.
Correct, although I would vote for such order even without any listening testsI liked nr 1 as most musical but a little less dynamic, nr 3 as most dynamic but also slightly unmusical. Nr 2 was somewhere in between .
I would say :
1. Sbooster
2. Nirvana
3. WiiM stock supply (?)
No I didntCorrect, although I would vote for such order even without any listening tests
Did you try to listen using ABX comparator or similar tool?
Just test yourself and your ears. Foobar2000 has built-in ABX comparator for example.No I didnt
Im happy to have had 100% correct listening results on this test , so - no thank youJust test yourself and your ears. Foobar2000 has built-in ABX comparator for example.
If you feel comfortable already with such riddles, I can prepare second set of samples, this time with the forth element to make it bit more complicated.
WiiM pro with electrical spdif out to my Rega Dac R .your wiim pro in analog (really not good) or in digital to dac? I didn't understand...
I know someone with an incinerator if you need any assistance in the disposal of said LP’s.FWIW, my collection of about 1,000 jazz LPs sits unused, as the vast superiority of digital reproduction is quite clear to these ears. I’ve been meaning to sell it off, but I’m too busy ( or too lazy).
Congratulations Musician! You certainly have very discerning ears!Im happy to have had 100% correct listening results on this test , so - no thank you
I guess the differences had been even bigger with stereo material and higher quality .
Well, I don't think so, but at least talking about "stereo image" would have more senseI guess the differences had been even bigger with stereo material and higher quality .
Hi Rudi, Which LPS did you use?Thank you for sharing, that is a very good sign, could it be that by listening differences can still be heard?
I am not here wanting to convince anybody of my ways of listening and testing. It's just that I like more listening with my heart than with my brains.
Of course I would like to hear improvements, but as I did in my previous post, if I am not happy with a change, I will tell so.
I am using the digital output, both coax and optical of the WIIM Pro, to see if I hear the same differences between the standard power supply and my new linear power supply. The digital signal goes into the Topping DX9 (not DX90 as I wrote somewhere by mistake). The DX9 is driving the very transparant HD800.
Used the same volume setting for all tracks, I have selected 6 unfamiliar tracks, 2 of these tracks are acoustic by artists I have both heard live several times:
Cuarteto Casals - on Qobuz and
Benjamin Appl - on Qobuz .
With the LPS I noticed the same tonality, but I get more involved, more experiencing the music. With the standard SMPS it is a bit flatter, less 3D, less euphoria for example with 'Boris Brejcha - Vienna', on Qobuz .
To me this is a no brainer, I'd like get more listening pleasureand the new LPS gives me that.
If you are in my neighbourhood (Amsterdam NL) and you want to hear for yourself if there are differences to be heard / felt, sent me a PM to see if we can meet. We are all unique, so it can very well be that your findings are different and that is fine and interesting.
edit type: heated -> heard
Using this one:Hi Rudi, Which LPS did you use?
Dank voor je snelle reactie Rudi. Gr,FransUsing this one:
AUDIOPHONICS LPSU25 Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA .
It is actually for 220 to 240 VAC input, they also make a 115VAC version.
Yesterday I have listened to music for over 12 hours, no listening fatigue at all, if it wasn't way past bedtime, I could have continued, such a joy.
However it makes me think; I might buy an IFI PowerX to compare it with the LPS, might be even better. And if worse, it will be of good use for something else in my system. Hans Beekhuyzen mentioned in one of his videos that for digital equipment a good SMPS is often a better solution.
rudi
edit typos: me -> be , Beekhuizen -> Beekhuyzen
