Aquaman
Senior Contributor
- Oct 20, 2025
I really don‘t know what this is all about.The WiiM device turns on my DAC, preamp, power amp, and subwoofer every three days, which is very annoying. I solved this problem by using Home Assistant to create an automation. The automation checks the player status using the WiiM API and sends an IR command to my DAC to turn it off if the player is in “none” status and the other parts of my stereo system are on. The trigger system then turns off all the other parts.
The WiiM performs an automatic reboot every three days according to your records. Ok, might be.
On rebooting it will trigger connected devices. That‘s what it‘s supposed to do. Then it will fall into standy after the predifined time and again will also trigger the shut-off of the other devices. All of this is according to the rules.
What‘s the problem?
