SKApretto71
Valued Contributor
- Oct 23, 2024
To add on this, even the WiiM Vibelink appears to have the same; it's not often noticed as it has both a signal timeout and the 12v Trigger, so if you do not happen to be awake at night (I agree with this conclusion. Mine was working fine before the silent reboots started.
It can be another reason why some brands/models appears to suffer, others do not. In the Topping D70 Pro case, mine, it has both signal timeout and v12 trigger, but those are mutually exclusive unfortunately, so it's either one or the other.
BTW: second day of my Ultra connected via Optical, as expected found the DAC OFF. Two days still to validate if Optical is different from USB.
