Update from the support team:Update from the support team:
"We have a whitelisted version with a 30-day silent restart period; would you like to be added to the list to try it out?"
I declined, suggesting is better to fix the issue than having occurring less frequently as it's clearly deterministic and can be reproduced by multiple users.
Same answer I got. I asked to clarify why it's not software, if the full reboot does not have this issue.This morning I received the following response to my ticket:
“This issue is related to silent restarts and cannot be resolved through software updates at this time. If the problem is particularly bothersome, we can provide you with firmware that enables silent restarts every 30 days.”
Best regards,
WiiM Support(Ethan)
Unfortunately this is not the news I was hoping for…
I had the same issue and I did raise a ticket quite some time ago. I didn't hear back so I cured it myself with a smartplug.all OFF as expected.
Yes, I agree and for this I referred in a past entry in this thread about some good advivces presented here as viable workarounds:I had the same issue and I did raise a ticket quite some time ago. I didn't hear back so I cured it myself with a smartplug.
I think it would be worth considering![]()
I have the same problems and WiiM add my device on the whitelist and downgraded my software to 5.2.736849. So I think it’s absolutely a software issue.Yes, I agree and for this I referred in a past entry in this thread about some good advivces presented here as viable workarounds:
1. Your - Smartplugs
2. Silent alarm - To be tested still but it's the first I'll try once confirmed that USB is not involved and nightly wake up of DAC will appears even via Optical
The good news is that support is reporting "they are aware of the issue and working on a resolution", the bad news is that they are asserting "it's not software related and cannot be fixed right now". Understanding this better is my current attempt in my mail thread with them.
I think - as far as they told me - that the whitelist impact is just that change the 3 days cycle to a 30 days cycle. But as you noted, this may come at the cost if an older build so possibly a miss on new features. Let see in 31 days if it occurs on your device once again.I have the same problems and WiiM add my device on the whitelist and downgraded my software to 5.2.736849. So I think it’s absolutely a software issue.
Yes, this will be the last resort. I'm focused in finding a working solution because is a product feature, the 12V trigger, advertised as working and past of my selection when I picked the DAC. I ruled out the ones without such capability to find out that implementation is not perfect on WiiM side. Unexpected.There‘s a very simple but probably not very popular solution.
Power the whole system down when not in use/over night via a central switch.
This is what I do, not religiously but regularly.
Granted. It should work. I‘m with you on this one.Yes, this will be the last resort. I'm focused in finding a working solution because is a product feature, the 12V trigger, advertised as working and past of my selection when I picked the DAC. I ruled out the ones without such capability to find out that implementation is not perfect on WiiM side. Unexpected.
There will be workaround and will leverage those once I understand no other paths via other features are viable. The aim is even to help others with same problem to get a better context and options. I'm constructive and trying to be helpful for the larger community.
Btw,Yes, this will be the last resort. I'm focused in finding a working solution because is a product feature, the 12V trigger, advertised as working and past of my selection when I picked the DAC. I ruled out the ones without such capability to find out that implementation is not perfect on WiiM side. Unexpected.
Are we possibly talking about a Topping and not a WiiM issue?Btw,
Sorry if this is a silly question, but I believe the Topping DAC has an auto-standby feature. (My D30 pro has it.)
Is it possible to use only the auto-standby function without the trigger cable? (I don't remember clearly, but it might not have worked with the optical input..)
Yeah, since I'm not sure if the WiiM team can resolve this issue, I'm considering other solutions.Are we possibly talking about a Topping and not a WiiM issue?
I think the behaviour is linked to how the Amp/DAC device react when there is no trigger cable connected at all. Some devices default to OFF, some devices defaults to ON (mine is that way).Granted. It should work. I‘m with you on this one.
What I don‘t understand is that my system (Ultra —> power amp incl. trigger) does not have this problem. I had left it powered up for a few weeks before I started to turn it off at night.
Yes it can do an auto signal driven switch off after one minute, with auto wake up on signal.Btw,
I think there is no clear standard on 12v Trigger behavior, so it may be that is the Topping implementation that is not working along well... But users with other brands have the same, so is not 'just' Topping. As well, some Topping amp like the B100 seems not to have any problem as an user reported.Are we possibly talking about a Topping and not a WiiM issue?
