I think you may be correct. Although, I believe I’ve heard of other people using PO 100 without having this issue. My next step is to try a DAC that has its own power inout.I have tried to connect the very same way as you with exactly the same result, but when I removed the smsl po100 the volume was normal. It looks to me that the smsl needs more power, maybe from a usb hub.
Interesting! I’ll have to give this a try. I sent the little DAC back assuming it was faulty. I’ll have to get another.I just experienced the same issue you are having. I think there is a bug when setting the volume bypass.I had the volume set to 30 before activating it. I set the volume to 100 before activating the bypass and voila, volume is loud again
Hi I plugged my WiiM Ultra into my DAC using usb and it was full volume, I wasn’t impressed with the sound though it was very sibilant.I think you may be correct. Although, I believe I’ve heard of other people using PO 100 without having this issue. My next step is to try a DAC that has its own power inout.
So you need a better DAC now?Hi I plugged my WiiM Ultra into my DAC using usb and it was full volume, I wasn’t impressed with the sound though it was very sibilant.
I guess I'm a bit dense, but I'm not following what you're saying here... Can you spell out the implications of what you're pointing to and how they would create the issue being pointed out?The volume of the USB output is implemented by the DAC but controlled by the Ultra via the USB protocol.
I think (but don't know for sure) that the WiiM Ultra provide the same volume control data to all external DAC's. So if some models sound louder than others it's down to the DAC implementation.I guess I'm a bit dense, but I'm not following what you're saying here... Can you spell out the implications of what you're pointing to and how they would create the issue being pointed out?
The DAC is set up in DAC mode, which just passed the signal straight through at 100%, I'm controlling the volume via the Ultra. I would consider switching things so I just control the volume via the DAC, but then I lose sub settings that I appreciate on the WIIM side of thingsI think (but don't know for sure) that the WiiM Ultra provide the same volume control data to all external DAC's. So if some models sound louder than others it's down to the DAC implementation.
What is the volume settings on the Ultra and on the DAC?
It is still the DAC that do the volume control, based on the volume data provided by the WiiM Ultra in the USB Control Transfers. The USB audio data should always be unaltered regarding audio volume.The DAC is set up in DAC mode, which just passed the signal straight through at 100%, I'm controlling the volume via the Ultra. I would consider switching things so I just control the volume via the DAC, but then I lose sub settings that I appreciate on the WIIM side of things![]()
But, then the WIIM sends 100% volume to the sub, and adjusting the volume on the DAC has no impact on the sub volume.You can do it both ways. You can use the Wiim as a digital preamp with volume control to feed a dac or you can bypass that volume control. There is a toggle switch in the app. I had the same issue and I was able to fix it by activating the volume control, setting the volume to 100 and then activating the bypass. Make sure that when you do that the usb output is active
I don’t have a sub so it works for me. Anyhow I thought usb output and sub output were not working yet. Wasn’t it in a beta stage?But, then the WIIM sends 100% volume to the sub, and adjusting the volume on the DAC has no impact on the sub volume.
It was until today - see: WiiM Ultra Firmware Release Notes : Audio Help Center https://search.app/UNzEoKqCh6k64WTV7I don’t have a sub so it works for me. Anyhow I thought usb output and sub output were not working yet. Wasn’t it in a beta stage?
Okay, I borrowed a friend's bluesound node and connected it to my D70 Pro Octo via USB, and had similar results, pointing to an issue with the DAC vs the WIIM. I'm personally considering this issue solved.I am having this same issue with my Ultra. I have a Topping D70 Pro Octo, and when I output from the optical cable I get a "normal" volume level, but if I switch to USB out the volume is nearly half of what it is via optical. I'll send a message to WIIM through the app and see what they say...
