WiiM Amp Firmware v5.0.714744 Update - Apr 23, 2025
Please review the WiiM Amp update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
5.0.714744 (In Progress)
Release date:
4 / 23 / 2025
What's New:
  1. Smarter HDMI ARC: Your WiiM AMP will no longer act as a TV speaker when not in HDMI mode—giving you more control. Learn More
  2. Track-End Sleep Timer: New option to pause playback at the end of a track—perfect for winding down. (Requires app update: iOS 3.1.9 / Android 3.1.8)
  3. Auto-Resume Playback for Soundtrack: Playback resumes automatically after OTA updates, reboots, or network reconnections.
  4. Group Volume via TV Remote: Control group volume directly using your TV remote.
  5. Wi-Fi Boost: Faster network scanning and connection times.
Bug Fixes:
  1. Amazon Music: Fixed playback issues for Prime users.
  2. Spotify Presets: Resolved unexpected ungrouping during group playback.
  3. TIDAL: Fixed skipping, playback errors
  4. Qobuz: Fixed track-start issues after skipping and unexpected playback jumps.
  5. Radio Paradise Enhancements: Resolved issues with track repetition during playback and fixed login failures caused by special characters.
  6. Alarm Fix: Resolved issues affecting alarms in Daylight Saving Time zones.
  7. General Performance: Stability improvements and behind-the-scenes optimizations.
It has been my experience with all of my WiiM devices.
That’s great. In my experience I’m always prompted to download and install. At no point has my device ever auto updated a firmware release without me saying yes. So if auto update is “normal” behavior, then I don’t like it. I don’t want to argue over everyone’s experiences. They are clearly different.
I think you would be able to raise a ticket with wiim and ask to be whitelisted from future updates.
He isn't saying he doesn't want updates just that updating automatically at a random time when you might unplug the device halfway through is a bad idea.
Most devices have a flashing indicator light when there's a firmware update and I'm certain that the WiiM devices do too.
My smart power switch can't see that ;) It turns the power off every night to all AV equipment. So I could be unlucky that an automatic update was happening at the same time. It should never happen.
How can you live with the risk? :ROFLMAO:
Firmware updates occur between 2AM and 5AM local time, so make sure your auto-off respects the time boundaries. I guess that yours will update either when you turn the gear on or never ;)
It does actually update after asking me, when I open the WHA.
Don't mix up two different topics.
If you don't like this behaviour, that's absolutely legit. But please don't question the experience of many other users (including my own) just because you didn't observe it before.
This is not a first, it definitely did happen before. And this is a thread for everyone to discuss the WiiM Amp firmware 5.0.714744.
The recent (last few days) updates for my Amp and Amp Pro, the Home app did indeed ask me, and didn't update until I said yes.
Perhaps the update happens automatically depending on how long it is between when the device/app notices the update is available, and when you next run the app. If that's more than a certain time, then the update happens automatically, perhaps? But if you start the app regularly, then you always see the prompt, perhaps.
This is a forum for questions and answers. If I have an issue that I never experienced I will ask questions. Never once did I questioned or disagreed with anyone’s experience.
My Amp is on always, even in standby. Wiim Amp firmware 5.0.714744 just magically showed up installed and ready to go. The WHA always asks to me install firmware updates. Never prompted never asked in this instance. That’s a FIRST in MY experience. I’m sure if I had 5 different WiiM devices I would have a similar experiences as others, I don’t. I have only one WiiM device. Not sure what topics I’m mixing up?
I apologise if you feel I was argumentative, that was certainly not my intent.
No worries 😉 I only have 1 WiiM device so my experience with this behavior is limited. If other devices get updated automatically without consent I wouldn’t know. My WHA usually prompts me to install. When that didn’t happen this time it was confusing.
It's alright then, nothing to argue about. You are not only free, but definitely invited to share your personal experience. As you said, that's what a forum is for.
If we mention that the same has happened before with all kinds of WiiM devices it's certainly not meant to doubt it never happened to you with the WiiM Amp before. That would be outright dumb and of no help to anyone. :)
No hard feelings at all 😀 You, in particular, and others have been helpful to me in solving issues I’ve had with my amp. You guys have made my WiiM journey go smoothly and I do truly appreciate it. Thank you.
I received the answer from WiiM support team about new hdmi behavior.
"We updated the HDMI behavior to align with the soundbar’s HDMI behavior. Based on user feedback that the new behavior isn't as expected, we are considering rolling back this change."
As the WiiM Ultra is not really a soundbar, even though some people use it like that, there must be at least two modes.
* Use as a soundbar and always outputs TV sound when TV is on (ARC always on).
* Used some times for TV sound (Music and movies) where manually select of TV input option will be only way that ARC is enabled.
When can I expect the previous way of hdmi auto sensing to return? Manualbe switching to hdmi every time I finish listening to music over wifi is annoying. It is after all not auto at all despite the name lol. It worked perfectly before, don't understand this change at all for wiim amp.
Totally agree. This needs to be corrected or rolled back ASAP.
