he hasn't measured anything that hasn't been known for a while about this type of approach and this chip...
(the arrival, implementation, put forward for several months of the pffb has just made the subject resonate differently, while it was voluntarily put aside in the name of "not too much impact and the cost/power" of these small classes d )
( impedance curve of his blade kef ?)
will just be case by case depending on the speakers, requirements etc. that's all...
(I don't care..just tell myself that if friends asked me their opinion..I would warn them regarding the amp-loudspeaker marriage..precautions to take..just that)
the requirements-needs of each other vary so much...that each one has to have their own experience...the prescriber effect on the internet clearly shows its limits in this area...He checked it out with several different speakers.
Maybe your friends didn't have room correction or EQ available on their Class D ampsthe requirements-needs of each other vary so much...that each one has to have their own experience...the prescriber effect on the internet clearly shows its limits in this area...
all my friends whose experience I know see their musical tastes, their quirks (hihi), who put them away had nothing to gain by doing so..it's worth to me the opinion of a stranger etc. I can sort things out a little.. ;-)
(I really wouldn't want to become a solution prescriber, or parrot things asserted on the internet, really not...but if I can warn friends...that I will...it's quite different ;-) )
I'm also not the one "to argue with someone" on such an unessential subject, let's stick with it..thank you
indeed...Maybe your friends didn't have room correction or EQ available on their Class D amps![]()
You posted to a WiiM Amp forum but I suspect you own a WiiM Pro Plus?On a different but much needed note, I set the filter thingy on startup and it's got an echo in the vocals, how do I get back to that menu option (im totally green about filters and just getting used to the wiim plus) please?
Here we go again! Can someone understand this?the requirements-needs of each other vary so much...that each one has to have their own experience...the prescriber effect on the internet clearly shows its limits in this area...
Did you find the filter settings you've been looking for?Yeah sorry it popped up in notifications while I was trying to find how to do it, I'm new to commenting on forums and saw the other settings above and asked without looking further at the post, I am very interested in the new amp though, and well impressed with my plus so far,selected one of the roll of things on rushing setup and couldn't find it again, haven't a clue what I'm doing, but thanks for the reply and understanding, got my ifi ipower 2 and it seems to be making the bass punchier and sort of smooths everything, could be placebo, wasn't impressed with Amazon uhd music through firestick Max and had no control over output, I'm waffling sorry
Hi @Smartplug I think all @canard saying is that he, and his mates, are not a fans of Class D amps from their experience perspective. And he respects that experience over the review of someone on the internet. He can make this judgement himself and the class D amps they have bought have ended up in the cupboard. But he does wish to tell people that Class AB is the 'don' of amp technology in his opinion and flag to fellow forum members what he sees as the deficiency of Class D amps.Here we go again! Can someone understand this?
O found the list with ql hl or something next to a list of frequencies but when I first set it up it gave me roll off settings i think, it's 5.45 am and i can't play with it , I have noticed when you power on the volume sets at zero, really got me looking for problems with my avr that weren't their till i accidentally pressed volume, just been watching Erin etc on their broadcast , only Joe and tell ever heard of wiim!! and Joe only had and knew about the amp that's available at the presentDid you find the filter settings you've been looking for?
I thought real audiophiles only used class A tube amps.Hi @Smartplug I think all @canard saying is that he, and his mates, are not a fans of Class D amps from their experience perspective. And he respects that experience over the review of someone on the internet. He can make this judgement himself and the class D amps they have bought have ended up in the cupboard. But he does wish to tell people that Class AB is the 'don' of amp technology in his opinion and flag to fellow forum members what he sees as the deficiency of Class D amps.
However he doesn't really want to get in an argument about it.
Class A will give you low power out due to heat generation and energy wasted but give you the cleanest pure fidelity. AB is the most common class used by audiophile.I thought real audiophiles only used class A tube amps.
I know that, but class D, in theory, has the same potential as digital audio in general. If perfectly implemented it has no crossover distortion. I’m not saying any product has achieved this.Class A will give you low power out due to heat generation and energy wasted but give you the cleanest pure fidelity. AB is the most common class used by audiophile.
They are switching, which means the driver is on or off. Binary. The analog output is derived from varying pulse width. The output is bandpass filtered to eliminate high frequency artifacts.The D in class does not stand for digital, btw. Class D are switching amplifiers, not digital amplifiers.
A switching amplifier can even be made as a DAC, sometimes referred to as a power DAC (or a digitally controlled switching amplifier). The technology behind is is purely analogue, still.They are switching, which means the driver is on or off. Binary. The analog output is derived from varying pulse width. The output is bandpass filtered to eliminate high frequency artifacts.
My point is, there is no crossover notch. No IM distortion. The output can theoretically be as clean as the signal from a really good DAC. I suspect it’s approaching that already at reasonable levels and with speakers that do not present unpleasant loads.
