WiiM Ultra Firmware v5.2.721349 - Jun 27, 2025
5.2.721349 (In Progress)
Release date:
6 / 27 / 2025
What's New:
  1. Time Sync: More robust NTP timing for music service login.
Bug Fixes:
  1. USB Search and Indexing: Resolved compatibility issues causing incorrect album indexing and search failures in the WiiM Home app.
  2. Empty Radio Fix: Resolved the issue where no radio stations were displayed on the Radio widget on the device screen.
The digital outputs make sense for sure on (ampless) Ultra since some people need an external DAC to provide balanced/XLR outputs if their power amps only have balanced inputs (they exist, for example like my Topping B200 monoblocs, or people running stereo amps in bridged mono mode with differential input like Schiit Vidars). That particular reason would not be a thing for Amp Ultra users given it has integrated power amp.
-Ed
I thought perhaps someone might say that. ;)
For myself, I have my Ultra going into a power amp to power my speakers, but then I also have the optical out going into an external DAC/headphone amp. Could be done with the Amp Ultra's USB out, but if you're already using that with a USB drive you need to add a hub, and all of a sudden the whole idea of the simplicity of a one-box solution is negated. In addition, not all external digital devices have a USB in.
There may be other uses for the digital outs which I've not thought of, and I suppose that's the whole point about flexibility.
Query. When a firmware update is applied, does it wipe out currently playing and recently played lists? I keep finding when I go back to the Ultra, it has forgotten all that stuff, and I'm not clear why. Is it possible for firmware updates to preserve these things in some way?
Release date:
6 / 27 / 2025
Bug Fixes:
Received it today and I confirm that USB Search and Indexing is solved.
Thanks for your support @WiiM Team , @WiiM Support . 👌
A reboot used to clear the recently played list on the Ultra but this has been fixed lately. So it should be saved also on firmware update.
Update: My Ultra just updated and the recently played list is still there.
Release date:
6 / 27 / 2025
What's New:
Bug Fixes:
Tidal has stopped working. Can not log in. Keeps saying Log in failed.
Power cycle your router, WiiM device and delete/re-install the WiiM Home app. If all that fails, raise a ticket to WiiM via the more/feedback section in the WiM Home app.
@WiiM Team Thank you for the continuous work on firmware. The frequent release of fixes, improvements, and new features was a major reason why I choose the WiiM Ultra and returned the Eversolo DMP-A6. I am really looking forward to the upcoming firmwares.
Unless Wiim approximates the beauty of USB scanning of the A6 it'll fall way back on that feature. A6 scanning is the future. It's almost plug n play.
