Wiim Ultra oddities
Status
Not open for further replies.
CABBY
Is it me or are this a correct design feature of the Ultra. When the device is off, why does it switch itself on when touched ? This is very annoying because if I want to reconfigure cables it means that I first need to unplug it from the mains . Standby mode on any devise should be a sufficient setting before unplugging cables safely
When my PC/notebook is in standby, I wake it up by moving the mouse or pressing a key/space bar and can work with the device again immediately. Only when I shut it down is it “off”. Standby is also required for Wake on Lan.
My Android phones with touch in standby are configured so that they can be reactivated and used with a double tap on the display. They are also woken up when a call is received and the screen is active.
My Ultra with Touch is also woken up with a touch (perhaps a double tap should be considered as an alternative setting here).
For me, these are desired and expected behaviors and what I understand by standby mode.
“Off” in the sense of powerless can only be realized by completely disconnecting from the power supply. Off in the sense of “shut down or not ready for operation” can be realized by a HW switch on the device or a SW command in the app. Just ask WiiM whether they will implement this in the app in the future. If not, there is still the option of getting either a switchable socket or another streamer.
I have a degree in electronics design, so maybe I’ve seen too much…
I consider a piece of electronics as being «hot» if it’s plugged into mains, on/off switch or not. So mains lead is always the last thing I connect and the first thing I disconnect.
Yep, that's how it works.. Internet radio is just a part the many services covered by the "Wi-Fi" source. Sometimes by pressing the play button while in "Wi-Fi" mode, it will actually pick up my previous streaming source. I think it depends on which service you were using, but I'd have to properly test this myself.
If you want a button to directly start playing a specific radio station, that's where the preset buttons come in hand
Is this twitter in disguise?? Anyway I mentioned about my Wiim coming out of standby overnight. I'm new here so didn't realise at the time that others had experienced the same thing. As I mentioned I turned off the Auto sensing on line, optical and and analogue in and no difference. I also mentioned that there is no option for USB so I disconnected the USB cable from my Wiim and so far it has been sleeping quite nicely. I've had my Wiim plugged into a Cyrus 8 Dac amplifier so maybe, even if the amp is in standby, it's waking the Wiim up.
Who knows but no big deal though, just buy and on/off switch, if I find it still wakes up.
You have to be really careful with what questions you ask the dictatorship is always watching, there are some who think that they own this forum forgetting that its actually a Wiim product. My Ultra has settled down too.
Apparently the Ultra reboots itself every three days, could that be causing the wake-ups?
This is a user forum, not an official WiiM site, so everyone have an opinion. If you ask here, then people will either try to help or argue against or for.
To ask WiiM for an feature then use the WiiM Home App feedback option.
Yes, but to allow reconnecting cables the way the OP want, only way is to cut the power completely. Even if the touch screen and all others was deactivated, there would still be power on all interfaces.
WiiM could have added a real power switch to the device but I don't see why.
Nothing wrong with this philosophy that's exactly how I understand it, but as I've said when a unit is in standby it should remain so. If a device has a standby mode the current won't pass this point . Not knowing that by touching a dark screen will activate it can be potentially harmful. There are many other forums about this topic they all give the same answer, better to be safe than sorry. So in this case the WIIM ultra should be put in standby mode first and the it is safe to remove the power cable. It is incorrect to just yank it out with the device still running
You have done nothing but insult people who have tried to be helpful in any way or to convince you of a common understanding of a function. And even now, instead of thanking them for their help or showing a willingness to compromise, you point the finger at them and write about dictatorship. That is ridiculous. I hope your cat is doing well with you.
Its owned by WIIM not by the users. If you don't like the topics posted then pass on by or do what you have just admitted that you do argue with the originator. You keep misunderstanding what my post is about. It might be a moan, so what. You have no right to keep telling me to contact Wiim Why don't you tell them that your getting tired of the topics that you have to keep reading. Or is this your daytime job?
Try to listen instead of shouting.
We have tried to explain how it works but you seems to ignore it.
I think that's how I wrote it 😉. The fact that the HW switch is not available can be researched before buying, I think this is due to cost reasons. However, you could at least consider the “shutdown” via a command in the app, so at least the cat problem or the problem of waking up on their own would be solved.
It has turned into a funny thread, so I have to read it!
Yes she is very happy thanks quite playful at times she will wack the CD drawer when it pops out and the DVD player when being used.
Hey everyone, let's try and keep it friendly in here! Standby power consumption is listed here but it's missing a few products right now, I'll get the team to confirm the correct levels and update the FAQ so it's accurate.
To be clear in case there are any questions, standby is not powered off. Networking components are still active, and inputs are waiting for signal to be turned on. Touchscreens are also ready to turn on if they sense a touch. If you're looking for a good way to fully turn devices off, it's better to use a power switch that's either remote or smart controlled, and to turn off the outlet that the WiiM device is plugged into.
I did however several times tried to explain but I see I can write whatever I want, you don't want to listen.
I am listening are you listening? how does anybody who has just purchased this device know that it will power on when a blank, black screen is touched.? If like me this type of device is a first time buy the only way to find out is by reading about how it works. When Its in full standby the only light on the front panel is in the center of the volume knob. Do I need to explain any more or is this not an obvious place to turn it back on. No I didn't remember everything that I had first read in chapter 1 so after various incorrect commands and going through the setup menu again, I just used the handset. At this point still unaware that it can be activated with just a touch, I turned it off I picked it up to look at the back panel I removed the line out leads and plugged in a new lead This is when I discovered it was back on. Now understand this correctly and don't try and twist it to mean anything else. All of this is not in the manual. All that you and many others have done is be critical of me not knowing this. You're not being helpful by saying its obvious, not everything is
From WiiM FAQ:
WiiM Devices Power Consumption in Standby Mode​
When in standby mode, WiiM devices enter a low-power state, allowing them to remain ready for quick activation while conserving energy. You can set the standby timer in the WiiM Home app to control when your device enters this mode.
Does it have power on/off button? Or is it always on?​
It doesn't have power button. It goes to power saving mode automatically when the device is idle to save power.
How do you turn power off?​
The WiiM Mini remains powered on as long as it is plugged in. If you need to turn off your WiiM device, unplug it from the power source. Alternatively, if you prefer to put your WiiM device into standby mode, you can configure the standby timing through the WiiM Home app. To do this, navigate to the "Device" tab, click on the gear icon, and select "Standby Mode" to set the desired timing.
Status
