🎉 Introducing the Vibelink Amp – Unleash the Power of Pure Sound 🎉
AD_4nXfvs54s98UfOTSBRzVSpxvPmRNbLlec-p99r5CenPY_874SCawk4vc3Uzos3r1a2uL0PK8pk5TuYmRp_4cfRsYaXP397YIU0nIUO4s1Hv2OtB-_oFK5aUat6rrlSmffBQpmd4iSeA
Hello WiiM community! We’re thrilled to announce the launch of our latest innovation: the Vibelink Amp! Designed with your needs in mind, this 100W per channel amplifier brings high-fidelity sound and unmatched versatility to your audio setup. Perfect for passive speakers, the Vibelink Amp ensures a premium listening experience when paired with one of our streamers, with a footprint designed to match the WiiM Ultra. By leveraging its premium DAC, Vibelink Amp is also a perfect match for WiiM Mini and WiiM Pro or WiiM Pro Plus via digital input for superior sound quality.
🔊 Why Choose the Vibelink Amp?​
  • 100W per channel at 8 ohms, 200W at 4 ohms: Experience powerful, distortion-free amplification for room-filling sound.
  • Premium unibody aluminum design: Sleek, durable, and thermally optimized for efficient heat dissipation during prolonged use.
  • High-fidelity audio with premium components: Premium DAC, amplifier, and op-amps
  • Post filter feedback technology (PFFB): Overcomes speaker's load-dependency
  • Bit-perfect playback (192kHz/24-bit): Achieve true audiophile performance with every note.
  • Anti-Pop Noise Design: Enjoy smooth transitions across variable sample rates and bit depths without interruptions.
  • Auto Standby & 12V Trigger In: Smart energy-saving features that fit modern setups.
  • Pure analog input (no ADC conversion): Savor uncompromised sound quality for your favorite analog devices.
  • Seamless integration with WiiM streamers: Effortlessly pairs with devices like the Ultra, Pro Plus, Pro, and Mini for high-resolution audio.
AD_4nXerpxGcnsbPzviuW6WVqqD84_9tcB-xETgegIXIzTr5kQ6aH8D77U8fX7dhW5VXRP-Gn5fpnJi6pMMdrE4JAuMzcx0DkcB91WjMb5CI4UyM5m6hn_88qFitnvknMJMIsYMUhkWyoA
🔍 Key Features You’ll Love:​
  • Hi-Res Audio Excellence: Packed with a high-quality built-in DAC ESS ES9039Q2M, one TI PCM9211 digital and analog front end, six TI OPA1612 Op-amps, and a TI TPA3255 Amp Chip, the Vibelink Amp supports up to 24-bit/192kHz high-res music allows you to optimize beloved, decades-old, high-quality audio systems or connect current speakers with your favorite platforms effortlessly.
  • Versatile Connectivity: Easily connect your favorite devices with analog (RCA) or digital (optical, coaxial) inputs.
  • Compact & Efficient: With a sleek, stackable design and cutting-edge thermal management, the Vibelink Amp fits right into your setup and stays cool even during marathon listening sessions.
  • Easy, Secure Connections: Standard stereo banana plug output ensures a solid connection to speakers, delivering high-quality sound without signal loss or dropouts.
AD_4nXfvSY4zCVEzcvdUWiyMg28Z9MlQSUGM9gYgLggqYRTnAYkrlfZ6LxlEEcvie9rqSADieUM5y43PT8ktAlF5ylfIZXNcnfvKC8uVwLPO7pj_qirUsHlg_0GNfXW3QRm8Zo776U0o
Why We’re Excited:
1️⃣ Compact Yet Powerful – A well-built, high-performance amplifier that delivers exceptional power in a sleek, space-saving design.
2️⃣ True Hi-Res Audio Support – Supports up to 192kHz/24-bit, ensuring full compatibility with high-resolution music services and user libraries, unlike many amplifiers that lack this capability.
3️⃣ Seamless Playback with No Artifacts – Effortlessly handles variable sample rates and bit depths between tracks, eliminating unwanted pops and clicks that occur in many amplifiers when audio resolution changes.
At WiiM, we’re all about listening to our community. Many of you asked for a powerful amplifier that delivers exceptional sound quality and integrates effortlessly into existing setups and we’ve been listening! The Vibelink Amp is a dedicated solution for passive speakers, designed to pair seamlessly with all WiiM streamers or as a standalone amp for your favorite gear. Whatever your setup, this amp brings the exceptional sound quality you’ve come to expect from WiiM.
The Perfect Match for WiiM Streamers​
✔ Seamless Integration – Designed for flawless compatibility with WiiM Mini, Pro, Pro Plus, and Ultra—just plug and play.
✔ Flexible Connectivity – Choose digital (Optical/Coaxial) or analog (RCA) inputs for maximum audio fidelity.
✔ Ultra-Low Latency – Perfectly synced playback for high-resolution streaming and immersive home theater sound.
✔ Studio-Grade Sound – Experience deep bass, crisp highs, and stunning clarity with bit-perfect precision.
Pair your WiiM Mini, Pro, Pro Plus, or Ultra with the WiiM Vibelink Amp and experience pure, powerful, and immersive sound like never before. Elevate your high-fidelity streaming with crystal-clear detail, deep bass, and room-filling audio.
🎶 Your music, perfected. Upgrade your setup today!
Pricing and Availability​
The Vibelink Amp will be available starting March 18th on Amazon US for $299, with international availability on its way. Don’t miss your chance to elevate your audio experience! Find out more on our website.
Let us know what excites you most about the Vibelink Amp, and share your setups! We can’t wait to hear your thoughts! 🌟
With the option of digital inputs which will allow even a WiiM Mini to benefit from the vibelink’s better DAC :)
Like terms such as bit perfection, I think sticking to rigid definitions of power amps etc isn’t as important as the benefits that the vibelink can bring to a range of streamers :)
That's kind of my thinking, pair it with a mini connected via S/PDIF. Obvious fit aesthetically with the Ultra, but that set up means you're paying for an extra DAC and volume control that wouldn't likely be used.
The DAC is technically an upgrade even for Ultra owners.
ES9039Q2M in the VibeLink vs ES9038Q2M in the Ultra.
-Ed
-Ed
Yeah, without having listened, no idea if that is a significant upgrade or something my flawed ears wouldn't be able to detect. Thinking I may grab one to pair with a mini in a satellite room, and once it's in the house I can do my own test without worrying about paying for a redundant DAC if I don't perceive a difference.
Let's say you had two swatches of material for furniture, or for paint colours, as you're going to be redecorating your room. And they're both a particular shade of turquoise, to the extent that they might actually be identical. What would you do?
Would you put one up on the wall where you can see it every day as you walked in and out of the room, then swap it for the other after a fortnight, and live with the other in the same way for two more weeks, then make a choice based on your memory?
Or would you just put the two of them next to each other?
I think you could make a case that testing audio equipment that way is more like living in a room where the entire room was painted one color, then repainting that room entirely with another color. I'm not dismissing straight A/B tests. But they're likely just that, tests, and not how I normally listen. To me they are analogous to comparing swatches, while extended listening comparisons can be a better approximation of what it will be like living with a sound/color on an extended basis.
Erm…I do. 🤷‍♂️
If you do an A/B test and give them identical, how could you possibly be satisfied with one after a fortnight, but then dissatisfied with the other, identical thing.
The one thing you could do. Listen over a fortnight, and find what you think is better about one than the other. Then do a blind A/B test and see if you can identify that difference.
If you can’t, that’s just your brain tricking you.
The same way I could go on a first date with two different woman and find that I didn't have a preference, but after spending a lot of time with both I clearly favor one over the other. Something that goes barely or completely unnoticed on that first date, in an environment very different from how I normally socialize and live, could become either very endearing or very annoying over time. Not everything reveals itself in a very limited sample size.
So A/B testing is more like speed dating then 😃
The mini doesn't have a trigger out so If the vibelink will be 'hidden' away at all and the right rear (as you look at it front on) is not easily accessibly then turning the vibelink on may be problematic.
Good to note. I don't think it would be an issue where I'm thinking of placing it. Nobody puts Vibelink in a corner.
