Introducing WiiM Sound: Your Smart Speaker for High-Res, Room-Filling Audio
AD_4nXd9pdn5vmIdlsudC_j9YSDmAoxv_PDGzsGsQ_qRgTDTlpl8aks5RZDcXq_fs3ruWLl6DHuJNaslVKO07_oYYg306NlhTpiL7wMaNyTXNvwnz0xhGTN08De4Kv1JUDqgkInpT8RZ
📢A landmark moment for WiiM! WiiM Sound, our first WiiM designed smart speaker, is here! The WiiM Sound is crafted from the ground up to deliver exceptional audio fidelity, smart connectivity, and seamless integration with the WiiM ecosystem.
After years of delivering award-winning streamers and amplifiers, we listened to our community and built WiiM Sound to fill a major gap in high-resolution, multi-room smart audio. With 24-bit/192 kHz playback, built-in room correction, and advanced EQ customization, this speaker adapts to your space and sound preferences like never before.
AD_4nXdltF_exblU5Ku1jhxDkd8_GFsA4fIb_3PU7yLrZGs6vOwd6l4g09d5GYgrO1PW905wEInLGpRZ3RMD34RYXzQv_BXFMQm39_ExgLVHm5N0fLc_O6l2WXEpsJxAoegUdHdJN_Io1Q
Why WiiM Sound?
  • High-resolution wireless streaming: Enjoy music, podcasts, Smart Preset and radio in stunning 24-bit/192 kHz quality—no phone required.
  • Next-generation connectivity: Equipped with Wi-Fi 6E, Bluetooth 5.3, and 100 Mbps Ethernet for fast, reliable streaming.
  • Advanced sound customization: Tailor your sound with 24 preset EQ profiles and a 10-band graphic and parametric EQ for precise adjustments.
  • RoomFit: Previously Room Correction, actively takes precise acoustic measurements of your room, crafting customized corrections for your audio equipment.
  • Stereo pairing: Seamlessly pair two WiiM Sound speakers to create a left/right stereo setup and expand your soundstage.
  • Home theater integration: Functions as a surround or center channel speaker in a Dolby 5.1 setup for immersive home cinema experiences.
  • Universal casting support: Stream directly from your favorite music apps using Chromecast, Spotify Connect, TIDAL Connect, DLNA, or Alexa Cast.
Immersive, Smart, and Customizable Sound
Whether placed on a shelf, counter, or wall-mounted, WiiM Sound seamlessly blends into any space while filling it with room-filling audio.
✅ 100W power delivered through a 4” woofer and dual tweeters
✅ Automatic room correction for personalized acoustics
✅ Stereo pairing - connect two for a true left/right speaker setup
✅ Multi-room sync - stream across your home with WiiM, Google Cast, or Alexa multi-room
High-Resolution Streaming & Universal Casting
🎵 Stream from over 20 music services or your personal library via the WiiM Home App
🎶 Enjoy effortless playback with Chromecast, Alexa Cast, Spotify Connect, TIDAL Connect, DLNA
🎤 Control hands-free using Alexa, Google Assistant, and the WiiM Voice Remote (WiiM Voice Remote included).
Powerful Connectivity & Customization
🔌 Wi-Fi 6E, Bluetooth 5.3, 100 Mbps Ethernet, 3.5mm Aux input for versatile connectivity.
🎛 Advanced EQ tools, including our 10-band graphic & parametric EQ, 24 preset EQ profiles, and input-specific adjustments.
🖥 1.8” high-res touchscreen display for direct control, album art, presets, and wallpapers.
🎭 Home Theater ready, use WiiM Sound as a surround speakers in a Dolby 5.1 setup with a WiiM device that has an HDMI ARC input such as the WiiM Amp Ultra.
Always Improving with Continuous Updates
🔄 Regular firmware updates unlock new features, services, and audio enhancements
Tech Specs
Connectivity: Wi-Fi 6E | Bluetooth 5.3 (SBC, AAC, LD3) | Ethernet | 3.5mm Aux
Sound Performance: 35 Hz - 20 kHz, 100W total output
Streaming Platforms: Chromecast, Spotify Connect, TIDAL Connect, DLNA, LMS
Multi-Room Audio: WiiM | Google Cast | Alexa Multi-Room
Smart Preset & Alarm Clock for personalized listening.
Dimensions: 5.7” x 5.7” x 7.5” (146 x 146 x 193mm)
Weight: 5.5lbs (2.5 kg)
Pricing & Availability​
WiiM Sound launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com. Update: WiiM Sound will be $299 US, £299.00 UK, and €349.00 EU when it becomes available.
Attn Wiim Marketing
Want to sell a ton of the new Wiim Sound lites? Add a long lasting rechargeable battery. Boom! Instant hit….Wiim goodness on the go. Simply remove from its charging base and take out on your deck, patio, back yard and let the music play. Sync it to all your other Wiim zones in your house and have that whole house party rockin! Put another dent in your competitors at Sonos & Apple. I’ve sold all my Sonos gear except for my “Moves” and very happily made the move to Wiim products. I have six zones in my house….and only held onto the moves for the purpose of moving them outside. I’d love to be able to have some Wiim Sound mobile lites and I’d wager there are many more like me out there that would swoop up a lot of these.
Attn Wiim Marketing
Inflicting your music choice at volume in public, or within earshot of neighbours, is one of the curses of the modern world! Only acceptable as outside concerts. 😁
Anyone tried the Sound’s Remote 2 with the WiiM A10? I find that If I turn the A10 off with that remote’s On/Off button I cannot turn it back on again - only solution is to reboot the A10 with the WHA.
I'm using my Remote 2 Lite with my Ultra, and it all seems to work as expected. So I have just paired an original Voice Remote with my C10, and am unable to reproduce your issue.
Perhaps an A10 owner can try to reproduce the issue.
Fine here for me - I paired the Remote 2 Lite that came with the Sound with the A10 and can turn it off and back in no problem. Does the remote maybe need to be fully charged?
I will check that but don’t think it’s the problem, given that other functions work fine. I miss the WiiM Sound. 😩
Yeah it works. What happens is if the remote off is set, when turned on it remains silent. One needs to click play. So 2 clicks. To me it would make more sense to restore the playback prior to turning it off.
I'm afraid I didn't quite understand what you meant. If the music can resume playback, pressing the remote's play button once will put it turn on and resume playback. (Of course, the same applies when you press the preset button.)
Simply pressing the remote's power button will not start playback.
My Remote 2 Lite also works fine with the A10. Pressing the power button lights up the A10's LED.
Yes, like you said but… a conventional tuner or radio when turned off and on again plays the previously tuned station. That paradigm is not followed here. No big deal.
Normally the play button on the remote serves that purpose.🙂
I am considering getting a Sound and Sound Lite to run as a stereo pair from my turntable with built in phono stage.
If I connect the line out from the turntable to the aux in on the Sound, is it able to broadcast that wired input and run wirelessly as a stereo pair with the Sound Lite?
Yes. 😁
Any update on wall mounts and speaker stands that would be available in the US? I'm ready to buy once I have that figured out. The NorStone looks great but getting it seems to be a challenge.
Yep, as soon as we have a list :) We're also working with some companies that are specially making stands. Currently, NorStone has a Floor Stand and Wall Mount for Wiim Sound Speakers. But there will be more in the future.
Do you have any updated information on this, and more specifically any stands that will be available in the UK.
Is wiim going to offer any 1st party mounts/stands for this series? I still have not been able to get the NorStone mounts into the US. I do have some pre-ordered but no ETA. Working on a few different projects and really want to recommend these to clients but without a good mounting system I'm DOA.
