Many Users are expressing their Expectations for this Feature - based on their understanding of Implementations on other Products by other Dev Teams. Only the WiiM Team can determine which set of Goals and Criteria they are/were working toward, what Limitations (Time, Resources, Hardware, Cost) were set.Is this feature completed as the title of this thread suggests? Many users are saying this feature isn’t 100% ready?
WiiM say it basically works in the same way as syncing between rooms and they aren't trying to optimise phase at crossover. So as far as they are concerned it is complete.Is this feature completed as the title of this thread suggests? Many users are saying this feature isn’t 100% ready?
Do we really know what/how they implemented the "Timing Alignment" Feature?? Do we know that some aspect of "Phase Alignment" doesn't happen, or at what Frequency they calculate that Alignment?? Or are we working from "the Lack of Mention of Phase Alignment" in posts by WiiM Staff?? Doesn't any implementation of Timing Alignment imply effectuation of Phase Alignment, too?? Isn't that likely where some of the anecdotal claims of "wildly wrong" Subwoofer Distances/ Timing might arise (remembering that a single wavelength at 60Hz is about 18ft - so a 10ft/8ms difference would effect a 180* Phase Alignment)??WiiM say it basically works in the same way as syncing between rooms and they aren't trying to optimise phase at crossover. So as far as they are concerned it is complete.
So it depends on who you ask?WiiM say it basically works in the same way as syncing between rooms and they aren't trying to optimise phase at crossover. So as far as they are concerned it is complete.
We know because of these postsDo we really know what/how they implemented the "Timing Alignment" Feature?? Do we know that some aspect of "Phase Alignment" doesn't happen, or at what Frequency they calculate that Alignment?? Or are we working from "the Lack of Mention of Phase Alignment" in posts by WiiM Staff?? Doesn't any implementation of Timing Alignment imply effectuation of Phase Alignment, too?? Isn't that likely where some of the anecdotal claims of "wildly wrong" Subwoofer Distances/ Timing might arise (remembering that a single wavelength at 60Hz is about 18ft - so a 10ft/8ms difference would effect a 180* Phase Alignment)??
Apologies for the confusion - I was referring to the mic on the WiiM device.When you say it uses the device's built in mic do you mean the phone mic? What happens if an external mic is used?
I read that Housecurve also has a timing alignment feature so I don't understand how that can be a different approach. I am now more confused by your clarification than I was before![]()
Someone should definitely try that and compare the results to REWFor anyone having issues with the mic used for this delay measurement, there is a super simple fix.
Move the wiim to your listening position during the measurment!
Yes you would need to add a longer cable during this, but that would not affect the measurement.
Yes currently!So when it does the delay, it uses the mic in the wiim device itself? Not the UMIk1 remote?
huh?
Yes currently!
It doesn't say anything in the app about the mic at all. Probably because there is no choicewow that's pretty daft. And nowhere does it show that on the app/process
No but really, I understand its a bit silly to measure delays with a device not on your listening position, but how often do you perform these type of measurments (”Subwoofer and Speaker sync” / ”Sync Audio”) ?
Just put the Wiim where you are usually sitting when listening and now you will get the correct distance to the mic from your speakers.
Easier to do with an Ultra than an Amp with speaker cablesNo but really, I understand its a bit silly to measure delays with a device not on your listening position, but how often do you perform these type of measurments (”Subwoofer and Speaker sync” / ”Sync Audio”) ?
You could use Wifi for this occasion, and perhaps borrow a cable.To put the ultra where my head is I'd need longer coaxial cable, ethernet cables.
you will have to wire the Wiim audio to the DAC or pre-amplifiers speakers subwoofer.... not only wiim movedYou could use Wifi for this occasion, and perhaps borrow a cable.
But yes it’s a hassle, it is a simpler solution though than having to calculate and add additional equipment just for a one time measurement.
Not saying its perfect, just giving a solution.
