Manual adjustments are already in place.There is no manual adjustment? I hope it!
Oh is there a manual delay adjustment tab? I'm looking for wiim, and I used it few months ago, so I didn't know about it!Manual adjustments are already in place.![]()
Unless the sub is right next to the music listening (& mic) position and the speakers are far away it would not be normal for any adjustment to be made to the sub therefore the WiiM calculation is within a range that would be expected.Just tried it. It doesn't tell you which microphone it is using which I thought was strange. I used the iMM6. It plays a high tone followed by a gap then a mixture of tones another gap and finally a low tone. The automatic result was 8ms latency adjustment of the main speakers. My previous manual adjustment was 6ms latency adjustment of the subwoofer. I have no idea about the methodology behind the automatic setting or if the setting is correct or not. It sounds fine to me with both settings.
The sub is sitting between the main speakers next to the right speaker. I don't have any reason to doubt the result but it would be nice to know how it was arrived at.Unless the sub is right next to the music listening (& mic) position and the speakers are far away it would not be normal for any adjustment to be made to the sub therefore the WiiM calculation is within a range that would be expected.
On AVR when doing room correction they go by feet. I’m not sure how many ms per foot.The sub is sitting between the main speakers next to the right speaker. I don't have any reason to doubt the result but it would be nice to know how it was arrived at.
Yes I have heard that before but these are right next to each other.On AVR when doing room correction they go by feet. I’m not sure how many ms per foot.
It's possible that there is a phase anomaly between sub and speakers so the WiiM algorithm is delaying the speakers more because of this. An 8ms delay is 'virtually' placing your main speakers 2.7m* behind the sub so that the sound peaks hit the microphone concurrently. It might be worth reversing phase on the sub and repeating the measurement.The sub is sitting between the main speakers next to the right speaker. I don't have any reason to doubt the result but it would be nice to know how it was arrived at.
With measured timing did the sub and speakers sync seamlessly and made the sound cohesive and engaging?Yes I have heard that before but these are right next to each other.
That could well be the reason. Before I started using the delay I did have the phase set to 180 degrees. I will try repeating the measurement with the phase reversed if only to see if the delay changes.It's possible that there is a phase anomaly between sub and speakers so the WiiM algorithm is delaying the speakers more because of this. An 8ms delay is 'virtually' placing your main speakers 2.7m* behind the sub so that the sound peaks hit the microphone concurrently. It might be worth reversing phase on the sub and repeating the measurement.
I will try to explain using these examples from old measurements taken from my system using an Earthworks M23 Mic
The top image is the initial impulse peak of the main speakers (37ms)
The Lower image uses the initial impulse peak of the sub (41.6ms) as shown by the first dotted vertical line.
So the delay to the main speakers needs to be 41.6 - 37 = 4.6ms
However if the phase on the sub was reversed 180deg then that image would be upside down & the large dip would then be the initial peak at 59ms (second dotted line) so the delay required for the main speakers would now be 59 - 37 = 22ms.
Neither speakers nor sub have changed position in the room but a change in phase changes the point in time that the signal arrives.
In your case I suspect that the WiiM algorithm has made the 'correct' adjustment so you do not need to worry!
(*sound travels at 0.343 meters per millisecond so 8ms = 2.744)
As far as I can tell yes.With measured timing did the sub and speakers sync seamlessly and made the sound cohesive and engaging?
Good, thanks!As far as I can tell yes.
Tiny addition: Generally speaking, a latency of 8 ms is virtually placing the mains ~2.7 m behind their own physical position, regardless of where the sub is. In this case the distance to the sub is assumed to be identical to the distance to the mains, so the above statement is still true, of course.An 8ms delay is 'virtually' placing your main speakers 2.7m* behind the sub so that the sound peaks hit the microphone concurrently.
As can be seen in those screenshots, it's quite a bit harder to exactly determine the location of the initial impulse peak of the sub automatically (irrespective of the polarity setting, colloquially referred to as phase). The high frequency components required for a sharp peak are missing due to the limited bandwidth. The fact that WiiM have created a new measurement signal tells me they've been actively working on this and the results appear to be very promising.In your case I suspect that the WiiM algorithm has made the 'correct' adjustment so you do not need to worry!
Do you know more than the rest of us does?I think wiim will stop refining their rc once the timing, independent peq rc, auto level and multiple sweep are out in public.
When you run rc does it include the timing in all the process?It's in the subwoofer settings
I see that menu in my settings. The thing is nothing has changed. It’s still the manual settings.It's in the subwoofer settings
Did you have the latest app?I see that menu in my settings. The thing is nothing has changed. It’s still the manual settings.
That’s what I was wondering.When you run rc does it include the timing in all the process?
