slartibartfast
- Apr 18, 2024
What is your firmware version?I see that menu in my settings. The thing is nothing has changed. It’s still the manual settings.
No, it is a separate setting.When you run rc does it include the timing in all the process?
Yeah I just checked the App Store and last update was 2 days ago.Did you have the latest app?
Well, I switched the phase to 180 degrees and still get the same 8ms delay.It's possible that there is a phase anomaly between sub and speakers so the WiiM algorithm is delaying the speakers more because of this. An 8ms delay is 'virtually' placing your main speakers 2.7m* behind the sub so that the sound peaks hit the microphone concurrently. It might be worth reversing phase on the sub and repeating the measurement.
I will try to explain using these examples from old measurements taken from my system using an Earthworks M23 Mic
The top image is the initial impulse peak of the main speakers (37ms)
The Lower image uses the initial impulse peak of the sub (41.6ms) as shown by the first dotted vertical line.
So the delay to the main speakers needs to be 41.6 - 37 = 4.6ms
However if the phase on the sub was reversed 180deg then that image would be upside down & the large dip would then be the initial peak at 59ms (second dotted line) so the delay required for the main speakers would now be 59 - 37 = 22ms.
Neither speakers nor sub have changed position in the room but a change in phase changes the point in time that the signal arrives.
In your case I suspect that the WiiM algorithm has made the 'correct' adjustment so you do not need to worry!
(*sound travels at 0.343 meters per millisecond so 8ms = 2.744m)
It look like there’s only 2 beta testers. It doesn’t look like it has issue.
What do you mean?It look like there’s only 2 beta testers. It doesn’t look like it has issue.
I’m only seeing you and @slartibartfast saying something about this beta. Maybe there’s more but not saying anything aside from reporting issues.What do you mean?
Oh ok I see what you mean. It’s possible wiim might have to iron out some more kinks. I figured the timing would have been built into RC.I’m only seeing you and @slartibartfast saying something about this beta. Maybe there’s more but not saying anything aside from reporting issues.
Yeah not sure what’s going here. I wasn’t on beta last night. I signed up for WiiM to whitelist my amp yesterday and I come home from work and now is she is in beta. Who knows lolThat is a different beta. Different to mine at least, mine isn't even marked as beta.
His build date was June 24, that maybe different beta.That is a different beta. Different to mine at least, mine isn't even marked as beta.
JuneHis build date was June 24, that maybe different beta.
Yeah this is the beta where I am able DLNA audio out. I think they gave me the wrong beta.His build date was June 24, that maybe different beta.
Build DateJuneWhere did that come from? How could that appear today?
Yes you got wrong beta should be same as him.Yeah this is the beta where I am able DLNA audio out. I think they gave me the wrong beta.
Since yours is labelled as beta you can leave it by clicking on it and choosing to leave.Yeah this is the beta where I am able DLNA audio out. I think they gave me the wrong beta.
Send them message so you can get same firmware as him.Thanks guys leaving that beta now and going on the normal version. We’ll see what happens.
