AudioPervert
Active member
- Aug 18, 2024
NorwayI got one from mcru. Are you in the UK?
Define “upgrade” thenI like upgrading my system anyway, doesnt have too improve sound quality
Spend moneyDefine “upgrade” then
Waste money you mean. Hey it’s your money go ahead.Spend money
ExactlyWaste money you mean. Hey it’s your money go ahead.
I am not following. Why do you consider the plug on this too big for the back of the Ultra?I think the plug would get on the way on that one. Might be easier to get something with a smaller profile.
www.audiovisionsf.com
I might accept that a power supply can influence SQ but not the basic cable ahead of the power supply. That’s crazy.
Yes you're right, it looks like it's low profile enough. Either way best to purchase from somewhere that accepts returns, so if you hear no difference you can send it back.I am not following. Why do you consider the plug on this too big for the back of the Ultra?
Wireworld Aurora Mini Power Cord (LIMITED STOCK SALE)
SPECIFICALLY DESIGNED AND RECOMMENDED FOR BLUESOUND AND SONOS. With the same advanced design as the Mini Stratus, upgraded by adding a thick layer of silver on the OFC strands, the Wireworld Mini Aurora 15 AWG power cable preserves more musical detail and dynamic expression than previous power...www.audiovisionsf.com
Just by the looks of it I can already say that this cable will have absolutely nothing to add compared to your stock cable. There's no shielding or anything since it doesn't have a GND pin to begin with. To me it's looking rather cheap even. The only difference is the twisted cable, probably just adding 20% - 30% in length to the actual conductors inside. Not worth the premium price.I am not following. Why do you consider the plug on this too big for the back of the Ultra?
It says specifically designed for bluesound and sonosThink i will buy it just because i can![]()
Maybe they need itIt says specifically designed for bluesound and sonos![]()
Good point. Perhaps the WiiM does not need it. But it wants it!Maybe they need it![]()
It's advised to have longer power cables, at least grounded ones and in terms of the audio quality.It says specifically designed for bluesound and sonos. But buy the two meters one. Wireworld states in general for its power cables that their power conditioning effect is more effective in bigger lengths.
If im grounded too my record player, im grounded?It's advised to have longer power cables, at least grounded ones and in terms of the audio quality.
It needs more thorough investigationIf im grounded too my record player, im grounded?![]()
The wiim is grounded?It needs more thorough investigation![]()
