Introducing WiiM Sub Pro: Experience Bass Like Never Before
🔥 WiiM expands into deeper sound! Meet WiiM Sub Pro, our first-ever subwoofer, designed from the ground up to deliver deep, distortion-free bass with AI-driven precision. Whether tuning your music, movies, or gaming setup, this sleek sub delivers precision through its 8-inch driver and Class-D amplifier, boasting a frequency range of 25Hz–200Hz which adapts to your space for optimized performance.
After years of perfecting streaming and amplification, we listened to our community and built a subwoofer that enhances your audio setup with clean, powerful bass and seamless wireless connectivity.
AD_4nXfYN4BgslKzRUjXM6VFt6p0Fc6uHIGOsa87gMd-OkdMA1hWqWeszI_RlVaUs281-laCb386CGUYJBa7aSAHmPcg1GYJw1MYEkKDuBD4sgn9i3TExHCNxi6-GcelqgzUgMBqSEwr
What makes WiiM Sub Pro stand out?​
  • Reliable wireless connectivity: Supports Wi-Fi 6E, 802.11 b/g/n/ac/ax 2.4 GHz, 5 GHz, and 6 GHz., Bluetooth 5.3 and RCA input enabling seamless connection to a wide range of audio setups.
  • Smart power management: Automatically enters standby mode and detects RCA signal or plug input to optimize energy use and simplify daily operation.
  • Precision sound enhancement: Includes Auto Room Correction for both the main speaker and subwoofer, ensuring optimized bass performance based on your room’s acoustics.
  • Flexibility of WiiM connectivity: Connect the Sub Pro with any WiiM streamer, amplifier, or speaker!
Seamless Integration with WiiM & Third-Party Devices​
Works flawlessly with WiiM streamers, amps, and speakers for tight bass performance. Pair WiiM Sub Pro with WiiM Sound, or enhance your existing WiiM setup for deeper bass and dynamic home audio. Have a WiiM streamer or amplifier without a subwoofer output? The WiiM Sub Pro can sync with them wirelessly to bring room filling sound to your setup!
Supports third-party devices via analog RCA mono input.
Key Features:​
  1. Powerful & Distortion-Free Bass
    1. 250W of deep, clean bass with less than 1% THD+N, delivering an immersive experience for movies, music, and gaming.
  2. AI-Driven Room Calibration for Precision Bass
    1. RoomFitâ„¢ Auto-Calibration takes precise acoustic measurements, adjusting bass to match your room size, speaker placement, and listening position.
  3. Next-Gen Wireless Connectivity
    1. Wi-Fi 6E for a low-latency, high-bandwidth connection, ensuring stable and interference-free performance.
    2. Bluetooth 5.3 with LE Audio for flexible connectivity with supported devices.
  4. Advanced App Control for Custom Sound Tuning
    1. The WiiM Home App allows for precise EQ adjustments, crossover tuning, phase control, latency customization, and subwoofer level adjustments.
  5. Elegant, Acoustic-Optimized Design
    1. Premium cabinet construction with custom-designed woofers, engineered for vibration-free, resonance-free bass even at high volumes.
    2. Sleek, modern aesthetics that blend effortlessly into any home décor.
  6. Seamless Integration with WiiM & Third-Party Systems
    1. Designed to work flawlessly with WiiM streamers, amplifiers, and speakers for a cohesive audio ecosystem.
    2. Connects easily with third-party devices featuring a subwoofer output, ensuring broad compatibility.
  7. Always Improving with Firmware Updates
    1. Regular over-the-air updates introduce new features, enhancements, and performance optimizations, keeping your system at the cutting edge.
Tech Specs​
🔊 Speaker: 8-inch driver | 25-200 Hz range | 104 dB SPL sensitivity
🔌 Connectivity: Wi-Fi 6E | Bluetooth 5.3 | Ethernet | RCA input
🎚 Subwoofer Control: Adjustable crossover frequency, level, phase, and latency
🎛 EQ: 10-band parametric EQ + automatic room correction
Dimension: 15.7 x 11.8 x 12.7 inches (399 x 301 x 322 mm).
Weight: 35.2 lbs (16 kg).
Pricing & Availability​
WiiM Sub Pro launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com.
🎶 Ready to feel the difference? Let us know how you'd use WiiM Sub Pro in your setup!
Hm, how could RC be run on the Sub Pro in isolation before pairing it with the main WiiM device (e.g. Ultra)?
What would be used as reference level to set the target curve if we didn't measure the full spectrum (sub+mains), and what about the crossover region?
As I see it, it only makes sense to run room correction after the Sub Pro is paired with a main device and crossover is optimized. It should still be possible to use 10 PEQs on the sub for the area below the crossover, and 2x10 PEQs (10 per channel) on the main WiiM device for the area above the crossover.
Can you explain in a bit more detail how this all works?
Is this any different to how other subs with an app on your phone work?
