Introducing WiiM Sub Pro: Experience Bass Like Never Before
🔥 WiiM expands into deeper sound! Meet WiiM Sub Pro, our first-ever subwoofer, designed from the ground up to deliver deep, distortion-free bass with AI-driven precision. Whether tuning your music, movies, or gaming setup, this sleek sub delivers precision through its 8-inch driver and Class-D amplifier, boasting a frequency range of 25Hz–200Hz which adapts to your space for optimized performance.
After years of perfecting streaming and amplification, we listened to our community and built a subwoofer that enhances your audio setup with clean, powerful bass and seamless wireless connectivity.
AD_4nXfYN4BgslKzRUjXM6VFt6p0Fc6uHIGOsa87gMd-OkdMA1hWqWeszI_RlVaUs281-laCb386CGUYJBa7aSAHmPcg1GYJw1MYEkKDuBD4sgn9i3TExHCNxi6-GcelqgzUgMBqSEwr
What makes WiiM Sub Pro stand out?​
  • Reliable wireless connectivity: Supports Wi-Fi 6E, 802.11 b/g/n/ac/ax 2.4 GHz, 5 GHz, and 6 GHz., Bluetooth 5.3 and RCA input enabling seamless connection to a wide range of audio setups.
  • Smart power management: Automatically enters standby mode and detects RCA signal or plug input to optimize energy use and simplify daily operation.
  • Precision sound enhancement: Includes Auto Room Correction for both the main speaker and subwoofer, ensuring optimized bass performance based on your room’s acoustics.
  • Flexibility of WiiM connectivity: Connect the Sub Pro with any WiiM streamer, amplifier, or speaker!
Seamless Integration with WiiM & Third-Party Devices​
Works flawlessly with WiiM streamers, amps, and speakers for tight bass performance. Pair WiiM Sub Pro with WiiM Sound, or enhance your existing WiiM setup for deeper bass and dynamic home audio. Have a WiiM streamer or amplifier without a subwoofer output? The WiiM Sub Pro can sync with them wirelessly to bring room filling sound to your setup!
Supports third-party devices via analog RCA mono input.
Key Features:​
  1. Powerful & Distortion-Free Bass
    1. 250W of deep, clean bass with less than 1% THD+N, delivering an immersive experience for movies, music, and gaming.
  2. AI-Driven Room Calibration for Precision Bass
    1. RoomFit™ Auto-Calibration takes precise acoustic measurements, adjusting bass to match your room size, speaker placement, and listening position.
  3. Next-Gen Wireless Connectivity
    1. Wi-Fi 6E for a low-latency, high-bandwidth connection, ensuring stable and interference-free performance.
    2. Bluetooth 5.3 with LE Audio for flexible connectivity with supported devices.
  4. Advanced App Control for Custom Sound Tuning
    1. The WiiM Home App allows for precise EQ adjustments, crossover tuning, phase control, latency customization, and subwoofer level adjustments.
  5. Elegant, Acoustic-Optimized Design
    1. Premium cabinet construction with custom-designed woofers, engineered for vibration-free, resonance-free bass even at high volumes.
    2. Sleek, modern aesthetics that blend effortlessly into any home décor.
  6. Seamless Integration with WiiM & Third-Party Systems
    1. Designed to work flawlessly with WiiM streamers, amplifiers, and speakers for a cohesive audio ecosystem.
    2. Connects easily with third-party devices featuring a subwoofer output, ensuring broad compatibility.
  7. Always Improving with Firmware Updates
    1. Regular over-the-air updates introduce new features, enhancements, and performance optimizations, keeping your system at the cutting edge.
Tech Specs​
🔊 Speaker: 8-inch driver | 25-200 Hz range | 104 dB SPL sensitivity
🔌 Connectivity: Wi-Fi 6E | Bluetooth 5.3 | Ethernet | RCA input
🎚 Subwoofer Control: Adjustable crossover frequency, level, phase, and latency
🎛 EQ: 10-band parametric EQ + automatic room correction
Dimension: 15.7 x 11.8 x 12.7 inches (399 x 301 x 322 mm).
Weight: 35.2 lbs (16 kg).
Pricing & Availability​
WiiM Sub Pro launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com.
🎶 Ready to feel the difference? Let us know how you'd use WiiM Sub Pro in your setup!
Avoid corners and walls: Corners amplify bass but often make it boomy or muddy. Keep the sub at least 12–18 inches away from walls if possible.
IMHO this is not very good advice in cases when room correction is available, which it is with WiiM systems.
Placing a sub in the corner will indeed increase overall bass level and the room resonances will be more pronounced - but that also means significantly higher clean headroom, while RC can easily knock down any resulting peaks. The intention is to have a very healthy bass level prior to RC.
On the other hand, with away-from-wall sub placement and using RC to e.g. boost deep nulls you can easily eat up headroom and drive the sub's amp into distortion.
So I'd suggest to instead refer to this article by Genelec on speaker and subwoofer placement. The physics behind their placement recommendations is sound. You can also refer to this post I wrote a while ago explaining some basic theory behind such placement recommendations.
Note that even this WiiM FAQ article recommends near wall and corner sub placement.
Hope this is helpful!
On the other hand, using later RC to e.g. boost nulls can easily eat up headroom and drive the sub's amp into distortion.
Good share! I should have linked that FAQ article. I was speaking pretty generally about sub placement, and point three was that RoomFit aka Room Correction can cover up a lot of things.
Agreed, however I wanted to point out that when you have RC the bass boost from near-wall or corner placement is actually desirable.
It provides additional 'free' bass headroom, and avoids SBIR nulls / bass suckout (which RC cannot fix).
Thanks, I couldn't agree more. The beauty of the availability of RoomFit is that it will take away any boominess while we can still take advantage of room gain.
Yes, RoomFit will to a degree deal with both situations, too high output due to close to corners positioning and too low output due to placement into the room. But the latter takes away from the amplifier power while the former reduces load on the amp and the driver.
The only thing to consider is that due to the slot loaded design we won't want to block the output on one side completely, so the back of the WiiM Sub Pro shouldn't be placed flush against the back wall. Placing it in a corner at a 45° angel is most likely just perfect.
With Room Correction corners are usually good choices for the reasons you point. The RC treats the boosts and with the other issues reduced it usually delivers a much better overall sound.
My main speakers (B&W 805S) which have front port have their backside at 5-10 cm only. This makes the front of the speakers (driver units) around 50 cm of back wall. I assure you that either with WiiM Room Fit and Lyngdorf RoomPerfect they sound like a charm.
Amazon put through the charge for my recent order. Previous experience tells me that the sub will soon be shipping. :)
I also noticed that they are showing out of stock now. U.S.
@RyanWithWiiM
Do RoomFit and 10-band PEQ use what is on the WiiM device side connected to the Sub pro? Or does the Sub Pro have these features as well as other WiiM devices?
Once connected to a room, the settings for the Sub Pro are mostly crossover, level and phase for the output. RoomFit is done by the WiiM device it's paired with, so that you can run it with all the audio in the room, not just the sub.
What will the AI feature do that wouldn’t be possible without the use of AI? Will I be able to disable the AI feature? I’d rather have a subwoofer that doesn’t require a massive server farm that uses obscene amounts of electricity and water to operate.
In this case, the AI feature is just part of RoomFit, it's only active when you run the room correction software and it's part of the tuning process.
