Thanks for sharing. Please let us know if you notice anything else that's changed...
Are you using WiFi or wired ethernet with your ultra?!
+ How are you powering the DDC and the DAC?!
It's a strange characteristic of the fairytale world of hifi that so much is devoted to arguing over the noises eminating from a few bits of electronics strung together with bits of wire. As far as it goes for me, I know when it all sounds okay to me and when it doesn't - I've had equipment which just was awful, others which disappointed, and stuff I've probably just got used to. That's how it is. 99% of the disagreements, put-down & claims of superiority, etc are essentially pointless.
If there are those who throw their money away on audiophile grade speaker weighting sand, or magic sound enhancing crystals, then so be it.
The money spent will gradually be redistributed within the economic system and just may at some point be used to better and higher uses (of course there's always the chance it'll all be used or diverted to purchase more guns, bombs, etc).
I'm off to watch another mindless crime series on Netflix
Reacher? Each new series is worse than the last. Ridiculous plot & cardboard characters acted badly. IMHO...we watched another episode of 'Reacher' for dinner on Prime today
What does crisper sound mean?Ok. Just received the SMSL PO100 Pro DDC. Oh boy.. seriously for me a huge upgrade. I think the most noticeable improvement is darker background (less noise maybe) as a result much more crispier and detailed sound of the instruments. Have been listening 3 hours straight after hooking it up into the chain with a big smile on my face, just wow!
As a reminder my setup now looks like this:
Wiim Ultra -> USB -> SMSL PO100 Pro -> Optical -> Geshelli J3 (Sparkos 2590 op amps and a dedicated LPS) -> RCA -> Musical Fidelity M3Si -> Buchardt P300
Sub: JL Audio D108
I don’t know the real science behind it, maybe the optical connection is isolating the noise much better compared to USB, or the reclocking is really a thing but definitely there is a big big improvement in my case. Hope this helps if someone is investigating this path. Cheers..)
Never mind crisper, is the sound more organic? What about its transparency?What does crisper sound mean?
 I used to believe much has to do with the quality of the source mp3
 I used to believe much has to do with the quality of the source mp3  file, more megabytes = more quality.)
 file, more megabytes = more quality.)...yes, but still better than the daily newsReacher? Each new series is worse than the last. Ridiculous plot & cardboard characters acted badly. IMHO
Ignore the news at your peril otherwise you won't see it coming until it smacks into you...yes, but still better than the daily news
The most obvious difference between DACs is so very, very obvious, you might easily overlook it: output voltage.much improved bass on my sub. I really don’t understand why since its still fed from the internal DAC of the Ultra, but I can clearly hear and feel this punching in my face )))
This is not standardised to 2 Vrms for 0 dBFS, it's just usually something around 2 V, give or take. Now, if an external DAC has a slightly lower output voltage than the internal DAC, but you keep the subwoofer output (employing it's own, unchanged internal DAC) at the same level as before, then - rest assured - you will recognise a dramatically punchier bass than before.
