You only have one Sub ? Assume looking at graph crossover is around 60-70Hz there is no output in the bass region below this, so no additive power from L or R speakers, just the mono from the sub.Thanks.
I used WiiM's Room correction audio file.
How did you measure the sweep with Sound Analyser Pro? I didn't know that was possible.Thanks.
I understand how to play it but how do you capture it with Sound Analyser Pro?When you run the RC, you will see the test sweep track on the Now playing screen. Then press the 3-dot icon to add it to your favorites. From then on, you can play it anytime from the WHA library.
I use two Android devices. I play from the phone and measure with a Galaxy tablet connected to the IMM-6C.I understand how to play it but how do you capture it with Sound Analyser Pro?
Hi, @harkpabst,
My speakers don't have 3dB of bass boost, is there something wrong with them?
Can you please let me know if you find a possible cause?
Thank you in advance.![]()
How do you measure a sweep with Sound Analyser Pro?I use two Android devices. I play from the phone and measure with a Galaxy tablet connected to the IMM-6C.
Sorry, I may not understand your question.How do you measure a sweep with Sound Analyser Pro?
I'll trySorry, I may not understand your question.
After opening Sound Analyser Pro, go to Advanced Settings and change MAX Hold to "Until Restart". If you are using an external microphone, set the Audio Source to "Microphone".
Measurement can be stop/start by pressing the play button on the measurement screen. When the sweep is played back from WHA, the MAX value will remain as a red line.
Can you zoom into the graph more, it looks very flat but that's quite deceptive. No point seeing -5 to 15db. REW allows you to do this. (mouse scroll wheel)
Next daft question. How did you display all three sweeps on the same screen?Sorry, I may not understand your question.
This app does not do that.Next daft question. How did you display all three sweeps on the same screen?
I'll do a proper test later.This app does not do that.
I used a Draw note app to overlay the 3 captured images and trace the lines, but it is a very tedious process.
Can you see the boost when you compare the 3 images side by side?
Hi @Wiimer, these results are really looking strange at a first glance. It looks like from 95 Hz downwards the level of the combined L+R measurement is constantly approaching that of each single measurement. Not only is there no additional gain. It's no gain at all.Hi, @harkpabst,
I must admit that I'm not fully aware of how you ended up with your setup. It's not the simple "Ultra does it all" setup, unfortunately, and yes, measurements look like mains and sub do not sum up nicely and cleanly. But if it sound good to you ... well.Yes,
Is the problem that the main and sub are controlled by two WiiMs?![]()
These are not absolute levels. The entire range top to bottom is 35 dB, horizontal lines are 5 dB apart. A little higher horizontal resolution wouldn't hurt but this is pretty much OK.Can you zoom into the graph more, it looks very flat but that's quite deceptive. No point seeing -5 to 15db. REW allows you to do this. (mouse scroll wheel)
The fact that this is happening pretty much exactly from the crossover frequency indicates some dependency here, but the picture isn't clear.
Your sub is rather far away from you and from the main speakers. This could cause some cancellation but if I did the quick math correctly, the first cancellation would be around 125 Hz where the sub out should already down by more than 10 dB (rough estimation). In fact I don't see any clear hint except for the slight combined dip around 250 Hz, but I don't have a clear explanation for that, either. Could be an effect on room modes due to the very symmetrical distances between speakers and sub (2 m and 4 m distance), but that's all speculation.
I was planning to add a subwoofer at some point, but it looks like I will need to buy the UMIK-1 before that.Maybe it's time for you to finally get a mic stand, a UMIK-1 and copy of REW to retrieve faster, more reliable and easier to analyze and maintain measurements.
Sorry I cannot offer a good explanation at this time.
Yes, perhaps this app is not measuring the lowest range accurately. I use other apps to adjust the bass.It is however a little surprising how much level there is doen at ~25 Hz. The single measurements are just 3 dB down coated to the maximum ~150 Hz.
Thanks for clarifying. I had assumed the sub to be on the same baseline as the mains. in this case my calculations regarding potential cancellation are not even remotely correct.In fact, the distance between me and the sub is 2.2 meters.
This is a floor plan of my room.
Previously had a sub in "S" but moved it to share one sub with room B.
Perhaps this is also a big mistake...
(But in any case, there is no place to put them near the main speakers.)
Sharing one sub between two systems is probably economically as far as money and space go but that placement could potentially do more bad than good. Difficult to tell.
