Flash2112
- Apr 16, 2024
I’m running my new-ish Pro+ from the USB on a Pro-Ject Accu Box S2 I already owned for a Phono Box S2 Ultra. The latter still fed from the 18v output.
Honestly don’t hear any signficant SQ benefit from the Wiim, maybe a touch cleaner but marginal at best. It does at least save a slot on the power strip…
"maybe a touch cleaner" then thats it and its all relative its like super expensive speaker cable vs happy shopper branded its marginal but all adds up power supplies can be noisy and really impact sound quality and introduce other unknown artifacts yes you can go overboard so I would suggest go with what matters to youI’m running my new-ish Pro+ from the USB on a Pro-Ject Accu Box S2 I already owned for a Phono Box S2 Ultra. The latter still fed from the 18v output.
Honestly don’t hear any significant SQ benefit from the Wiim, maybe a touch cleaner but marginal at best. It does at least save a slot on the power strip…
