I have a WiiM Pro which I am using with a Chord Mojo external DAC. Everything is working as it should apart from it won't output at any other frequency other than 44.1khz. I have tried adjusting the high res settings in both the WiiM Home app and in Qobuz, but the Mojo is always receiving a 44.1khz signal and never higher.
Has anyone experienced a similar issue and is there a work around/fix? Thanks!
