Sync issue with two amps
Coyote90
I have two WiiM standard amps. They each drive a pair of outdoor speakers. I had trouble with them playing in sync when I first bought them a couple years ago. One of the firmware releases fixed the issue and they worked perfectly. However it’s probably been almost a year since they have worked properly. There is about a 2 second delay between them. I have tried everything. Any advice?
Try group audio delay under audio input for the leader amp in the group.
There's no ability to change that for WIFI.
Yeah, it's fixed at 800ms.
A 2 second difference is massive.
This is with a Wiim group, right? What are you playing?
Never heard of that amount of difference before.
It’s the same delay if I use a group or not. Spotify. Iv tried Spotify connect through the Spotify app, or using the WiiM app. The only way I can make it work is playing music through my tv and running optical input to both amps.
