Test WIIM pro+ with different power supplies
Being linear is not mandatory here. Which leaves an open question - is it better to choose a high quality SMPS or similarly priced cheap LPS.
Very good question. I believe some high end manufactures specifically use (high quality) SMPS in preference to LPS.
I'll have to get searching / reading again; been a while since I found / read that.
Yeah, Linn’s Utopik power supply/module which comes in at £1350 is SMPS.
I use the LHY LPS, or Jay's Audio, same unit. They do make a difference, at least to my ear, and do not break the bank. I think the more sensitive your speakers are the more you will hear these SQ improvements. At least that is my experience with a pair of KLH Model 5's vs a pair of Zu Omen Dirty Weekends and their new DW6 Supremes. The difference on the Model 5's was negligible. The Zu's, immediate and noticeable. Just my experience, no measurements taken. Even the ifi power supply sold on Amazon made a positive SQ improvement, I think it is still around $79. I would recommend either, the LHY or ifi over the WiiM usb power supply.
The IFI iPower X performs well, it is 109, but they do pop up on the used market for less. It is at least as good or better than similarly priced linear supplies from Ali Express. Type isn't most important, build is. There just happen to be a gazillion of badly made smps's out there because they are cheaper, lighter en more efficient than linear solutions. Just not good for audio because noise isn't a factor in most applications so manufacturers couldn't care less.
I just would underline that the use of a decent linear power supply ensures that no HF-garbage is being emitted by a cheap and questionable switching power supply.
Even if the WIIM pro plus might "ignore" this HF-garbage - my analogue pre- and power amplifiers might not, as this HF-garbage ist not only emitted towards the WIIM pro plus but aswell back into the mains...
So I always do seek to keep the complete chain free from unnecessary "pollution".
The price of around 80,-- EUR for the LPS is -to my mind- modest enough.
A linear power supply also pollute the mains somewhat. And the magnetic field from the linear transformer can pollute nearby electronics.
A big 12 volt battery and a lm1084 regulator set at 8 volt followed by another linear regulator set at 5 volt is probably the best option, it will lower the batterys high output impedance . No pollution on the grid and the double regulation makes the ripple very low. Left is the noise from the regulator. I did try double regulation:
That LM3042 looks like a pretty kick butt IC. Very high specs. Data sheet has everything needed to DIY a supply.
Yes, Im not an expert but it cant deliver the current needed to drive a WiiM pro+. lm3042 is only spec at 0.2 A. You will need at least 1 A spec to be sure longtherm.
A lt1084 is better at delivering current and wont overheat with a proper heatsink.
Apple USB supplies are very good. Pick one with USB-A out and 5W or so.
Those are made for quickly charging iPhones, not for Audio. Don't buy it from shady sellers because they will likely be fakes.
I bought the Apple charger on for $6.49, there is info I believe on this thread about getting a real one. I have not tested it yet, using the iFi, will do so when I get done redoing some remodeling plans and modding my computers.
Please report your findings.
There are good reviews or at least one good review of it here and should be on this thread so please look it up as I am not sure when I will get to testing it, too many other projects right now.
I thought I saw it here but can’t find it. Anyone measured the typical and max current used by a WiiM Pro (at its 5V power input)? No line out use just WiFi in and coax out to a DAC.
Thanks! Yeah the Pro used very little current. A typical Apple 5V 1A power supply works perfectly.
Yes, but we don't know how much power it consumes during the firm update. I'd be happy if someone could measure these.
Shouldn’t be any more than streaming 192kHz/24bit. Certainly not more than 1A.
