steadyshot
- Mar 14, 2023
iPad charger is 12 v the drawback of iPhone charger is ripple . To me ifi power x is a nice upgrade
No , this iPad charger from 2012 has only 5 v 2A . Not 12 V as the newer ones.iPad charger is 12 v the drawback of iPhone charger is ripple . To me ifi power x is a nice upgrade
Yesterday I have bought a lm317 power supply board with a separate 9V 3A linear AC transformer to try with the WiiM pro. I will compare it to the iPad 2012 charger. 13 euro for the lm317 board so no big investment. Delivery from audiophonics before christmas.Next week a LPS (Linear Power Supply) should arrive for the Wiim Pro, which I am using as a streamer only, connected to a separate DAC. I will let you know if I hear an improvement in sound quality. I hope so, but proof is in the.
Is 9V okay for the Wiim, as it accepts 5V ?Yesterday I have bought a lm317 power supply board with a 9V 3A linear AC transformer to try with the WiiM pro. I will compare it to the iPad 2012 charger. 13 euro for the lm317 board so no big investment. Delivery from audiophonics before christmas.
Looking forward to your impression of your LPS.
The linear transformer output is 9V AC . This cant be used with the WiiM. It would destroy the unit.Is 9V okay for the Wiim, as it accepts 5V ?
Exciting times , both you and @Musician and me have power supplies coming in to see if and how the output of the Wiim can be improved. Are you using the analog or digital output of the Wiim?Update: I just ordered a used iPad charger on *bay for $6.49 shipped from a very reliable seller, it had a clear picture showing details so I know it is an original apply 5 volt charger..........
Same here, I am using the digital output only of the Wiim Pro, into Topping DX90 DAC / Headphone amp. Hopefully I will have the new LPS by the end of this week.Yes, I agree, great fun and not a ton of money, even better
I will be using an outboard DAC once I get a problem fixed on my temp system and certainly on our higher end system once I get it up and running but not ready to install it yet, still remodeling. For now testing the digital out only as that part of my system is working fine(Martin Logan Vision X soundbar, dang fine unit, listed for around $1700, bought it used for $225) I picked the Pro Plus though going to use an outboard DAC (Topping E70 Velvet) I wanted to take a listen to it with the analog outputs and I got it on sale for $175.
Interesting ! Maybe Im gonna buy the ifi power X later, to see If its even better than the iPad charger and the lm317 board, - for my listening preferences.Just a quick simple test so far and quite a noticeable change, everything seems just a bit crisper and cleaner, more detailed.
System, for now.
Pro Plus using their app on Android phone to control it.
Feeding optical to surprisingly good Martin Logan Vision X sound bar
Steely Dan Goucho from Qobuz, 24/192, 1st two tracks, Babylon Sisters and Hey Nineteen.
OEM PS and iFi iPowerx
I went back and forth twice each track and with the two PS units
I can hear a pretty significant difference so far as mentioned above, it is with the iFi PS though the OEM still sounds dang fine.
I will do a lot more testing with a lot more differing music but all very good tracks, some from my limited high end CD's but sold my main player Oppo 83SE as no longer fit in the space I have for a player so using a really decent Panasonic BD player.
I will try the batter bank next.
audiophilestyle.com
have to run, the OEM one is a bit easier to listen to siting right below the sound bar on the ceiling as not quite so not sure the term I should us, not sharp in a bad way, just really present, less laid back. Once I get the issue fixed with the SB and can use the E70 Velvet that might help a bit, I love the AKM sound though this one is supposed to be like a cross between a good AKM and ESS.Very good question - Its new technology and has the pontential to be great I suppose. But maybe most maufacturers use this right now only to make things smaller and maybe cheaper ?Has anyone tried a using a GaN charger and if so did they notice any sonic difference?
