slartibartfast
- Apr 18, 2024
I wonder if the WiiM Amp preserves absolute phase. I get a better result with the sub output switched to 180 degrees but I actually use a delay of 6ms which is half a cycle at 80Hz. I wonder if I should use 180 degrees instead.Nothing wrong with that.
The term "phase" usually describes a variation in timing relative to a full 360⁰ sine wave. The 0⁰/180⁰ "phase" switch is actually a bit of a misnomer because it doesn't shift anything in the time domain. It just inverts the polarity (or "absolute phase") of the signal.
Surprisingly, quite a number of amplifiers do not preserve the absolute phase and human beings are usually not sensitive to it. However, if you combine two separately amplified sources (like e.g. a sub and an amp with passive speakers or a a pair of active speakers) you should always check which polarity results in clean summation with no dips.
0⁰ or 180⁰, it doesn't really matter as.long as.the outcome is OK
