What products you'd like to see WiiM produce?
Sort out WiiM Home for MacOS. Would love to use it in my MacBook Pro but it’s so unstable I give up. iOS app doesn’t work on the MacOS
Have you submitted any bug reports to WiiM for the MacOS app? I’m aware it’s a beta but Wiim may be able to advise what additional info you may be able to send to allow them to identify the problems.
I'm guessing such remotes have fallen out of favour because if you want something that controls more and more devices, a tablet is the cheap solution that works.
Not really. You have to wake up the tablet, enter the application, find the setting and only then change the settings. The controller with buttons and a knob lies close to your hand and even in the dark you will immediately find the function you need without looking. If it charged once a month, it would be perfect.
And Wiim doesn't even have widgets so far.
To be honest, I am already getting tired of naming them Pro, Plus, Ultra, etc. and find them confusing, so I am hoping that the next new product will have a novel name. 😄
Keep it simple and easy to understand like Ultra II. Many brand uses those.
A Shakespeare range came immediately to my mind. Something like Romeo Stream, Julia Pre, Hamlet Phono, Othello Ultrissimo. Keeping the fantasy running 😇
This DAC is often mentioned as a good and cheap choice to pair with the Mini.
What's the context you are referring to?
Should WiiM make a stand-alone DAC?
Make all wiim products especially the Ultra's inputs/outputs assignable.
Fix volume increments with remote lol.
Otherwise at the current price points,we have no right to complain lol.
More power from amp. Maybe something with atmos support?. Tube amp? Your own powered speakers
How about a Wiim Ultra Plus with LPSU and i2s. For me the Dac is not interesting but I get that the market for a Non-dac streamer is to slim to get good profit
A USB in on the next Pro Plus would get me to upgrade my Pro and be a good answer to the new Bluesound Node Nano. I'd like the ability to hang a SSD drive off it.
