WiiM Pro Firmware v4.8.704151 Update - Jan 10, 2025
Please review the WiiM Pro update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
4.8.704151 (In Progress)
Release date:
1 / 10 / 2025
What's New:
  1. Persistent Group Support: Enhanced quick selection and synchronization for multi-room audio across devices. Learn more
  2. Replay Gain Enhancements: Replay Gain now supported for USB, NAS, Samba, and local libraries (requires app version 3.1.0).
  3. Soundtrack SDK Enhancement: Upgraded for a better listening experience.
  4. TIDAL Connect SDK Update: Upgraded for improved playback stability and resolved crash issues.
  5. Remote Volume Step Customization: Adjust the volume step for each press of the remote’s volume buttons (requires app version 3.1.0).
  6. Remote Troubleshooting Improvements: Remote exception status is now provided to the app to assist with troubleshooting (requires app version 3.1.0).
  7. Network Setup: In Setup mode, hold the play/pause button for 3 seconds to cancel the setup.
Bug Fixes:
  1. Playback Enhancements: Fixed playback status after seeking, resolved artwork issues via Google Cast, and added sample rate/bit depth display on Alexa.
  2. Alarm Fix: Alarms now stop correctly, even when the selected music is unavailable.
  3. LMS Volume Control: Resolved an issue where Fixed Volume settings were lost for LMS Volume Control.
  4. General Fixes: Various performance improvements and bug fixes.
After a recent firmware update, something strange happened to the WiiM Pro when using it as an squeezelite. The sound output level is much lower when streaming music from the LMS than when playing the same albums directly from the WiiM app. Do you also have this?
Are you using replaygain in LMS?
Check the replay gain setting under the three dot menu under home music share in the WiiM app to see if it’s a side effect of that.
Thank you for trying to solve the problem. But first I have in “home music share” replay gain disabled. Secondly, it seems to me that it does not apply to using Lyrion as a server.
I'm very worried about this, as LMS has been the primary use of all my WiiM boxes until now.
