Where do you sign up from?Signed up for early access to the Roon Ready firmware yesterday evening and within 3 hours it had been pushed. Works just great.
See comment #51, but I’d expect the public release to be available soon, maybe this/next week. You might be as well waitingWhere do you sign up from?
I’ve done the updates but the newest firmware I get is still the old one, no Roon support yet (only over Chromecast and A/Play).
Also rebooted the Wiim Pro and still no Roon connection.
Thanks!
Darko and others announced that the update will be 30/6 a few hours ago. Should be here any day I guess.In #32 WiiM mentioned the regular update for the Pro would be 6/30.
So if my calendar is the same it should be today.
I guess they’re rolling out the updates in batches. No sign of an update in this corner of the world4.8.521547 is available.
It's an official Roon Ready FW as it gives an access to Roon Ready service in the WiiM Home app.
Yes, no idea what pattern is used here.I guess they’re rolling out the updates in batches. No sign of an update in this corner of the world![]()
Yeah, they tend to rollout in batches, supposedly overnight but it can happen anytime over a day or two.I guess they’re rolling out the updates in batches. No sign of an update in this corner of the world![]()
And he states “That makes the WiiM Pro the most affordable Roon Ready endpoint on the planet.”Darko and others announced that the update will be 30/6 a few hours ago. Should be here any day I guess.
Any idea what was the cheapest RR streamer before?And he states “That makes the WiiM Pro the most affordable Roon Ready endpoint on the planet.”![]()
Up to a week I would say based on my experience.Yeah, they tend to rollout in batches, supposedly overnight but it can happen anytime over a day or two.
alleluia.. ;-)
He doesn’t say, but from a quick Google/look at the Roon forums, maybe the 250€ Argon Solo or 399€ iFi zen stream?Any idea what was the cheapest RR streamer before?
not for "mini"Ma conviction : Avec cette étape vers RR la WiiM est enfin la solution logique pour un streamer.
Cela le rend si abordable que l'argent économisé pourrait être utilisé pour tous les éléments environnants comme les amplis, les haut-parleurs, les DAC, etc.
It is incredibly good for the price!!My conviction: With this step to RR the WiiM is finally the logical solution for a streamer.
It makes it so affordable that the saved money could be used for all the surrounding stuff like amps, speaker, dacs and so on.
