WiiM Ultra Firmware v5.2.717053 - May 15, 2025
5.2.717053 (In Progress)
Release date:
5 / 15 / 2025
What's New:
  1. New Radio Widget: Quickly select and play a radio station directly from the screen.
  2. Audio Input Management: Choose which audio inputs to display and switch between them easily.
  3. Improved Group Playback Sync: Fixed synchronization issues that occurred after applying subwoofer and main speaker delay calibration.
  4. Enhanced DSD Playback: Resolved stuttering during multi-channel DSD file playback for smoother high-res listening.
  5. Group Mute/Unmute via Master Device: Instantly mute or unmute the entire speaker group directly from the master device for seamless group control.
  6. Device Discovery Enhancements: Improved stability and connectivity for WiiM Home, Spotify and TIDAL apps.
  7. Knob Volume Step: Adjust the volume step when rotating the knob (requires the upcoming app update).
Bug Fixes:
  1. A/V Sync Optimization: Enhanced audio/video synchronization for HDMI ARC to improve lip-sync accuracy.
  2. Plex Playback Fix: Resolved playback failure when Secure Connections is set to "Required".
  3. Standby Mode Fix: Resolved an issue preventing the device from entering standby mode when in follower mode.
  4. TIDAL Connect Fix: Addressed the issue of track skipping delay and corrected track duration when using the HTTP API.
  5. General Performance: Stability improvements and behind-the-scenes optimizations.
Thanks for the on screen Radio button and BBC sub folder, however they are the low bitrate (96) versions of the stations.
Any chance you could replace these with the higher (320) bitrate versions?
WiiM probably can't differentiate between UK and Rest of the World users so can't use the 320kbps streams.
Try using the links referred to in this post in Open Network Stream, or use the bbc sounds app and Chromecast or even airplay to your WiiM.
Hi @Jamiewednesday
We will check these versions of the stations. Usually, their bitrate should be 320kbps.
