WiiM Ultra Firmware v5.2.728233 Update - Sep 3, 2025
5.2.728233 (In Progress)
Release date:
9 / 3 / 2025
What's New:
  1. Enhanced VU Meter: Smoother and more responsive visual performance.
  2. TuneIn: Automatically selects the highest-quality stream.
  3. Screen Enhancements:
    • Added Spotify Connect support in Recently Played.
    • Presets now visible even without internet.
    • Device name displayed on the Home page.
    • Bluetooth connection status added.
    • Enlarged playback control button touch area.
  4. Audio Input Enhancements: Provided the plugged-in status and audio detection to the app for real-time display.
  5. Headphone Output: Disabled RoomFit™ profile when using headphone output.
  6. Smart DNS Enhancement: Improved Smart DNS by checking server accessibility for smoother streaming.
Bug Fixes:
  1. YouTube Music: Fixed playback noise and incorrect metadata.
  2. TIDAL Connect: Corrected metadata display.
  3. Qobuz Connect: Fixed the issue where gapless playback was not working.
  4. Google Cast: Fixed occasional no-sound issues.
  5. HDMI ARC: Fixed unexpected switching to ARC during music playback.
  6. USB Indexing: Fixed garbled Chinese character display.
  7. SoundTrack: Fixed missing audio during the first two seconds of announcements.
  8. YouTube Music Group Playback: Fixed no-sound issue when switching to group playback.
I've always thought that "sounds fantastic" somehow doesn't fit here. "Looks fantastic" would be better, since you can really only compare the measured curve with the target curve in the image.
The evaluation function does honour the balance setting, so it is possible to perform a measurement of just the right or just the left channel, if this is all you want.
Sorry, where is the option just to Evaluate the eq / roomfit settings (I couldn't find it)? :S
If you haven't made any changes to the RoomFit profile it is expected that you get the same curve as you did at the end of profile creation.
However, some people make manual changes to RoomFit profile parameters, or add EQ on top: the "Evaluate" function then lets you see how these changes affect the in-room response.
E.g. I like to create my own room correction filters with REW and then manually load them in a RoomFit profile. The "Evaluate" function lets me easily check if the REW filters do what I intended.
There's no need to do anything. Actually, if you were happy with the sound after creating the profile, there's no need to run the new "Evaluate" function at all. However, if you made some changes to RoomFit or EQ the "Evaluate" function will allow you to see what the change did to the response.
On this note, I do hope @WiiM Team consider adding the "Individual Channel" option to the Evaluate function. It would be useful to see measurements of each channel individually post-RoomFit and post-EQ
The labels on the buttons could be a bit misleading, I agree. "Sounds Fantastic" should probably be replaced by just "Close" or something similar.
Hope this helps!
Hi @dominikz
Thx very much for your detailed reply. Helped me to understand. Much appreciated :giggle:
On my opinion WiiM should add one more option. The possibility to esclude with one touch both RF and EQ. With a dedicated button would be possible activate/deactivate both corrections. Very useful to do a test with/without on the fly
It depends on what you expect from it...
A VU visualization that gets -mad thumping- off scale when you turn the volume knob in "original signal" mode is not my cup of tea.
An unpleasant and worsening update, at least for me.
Confirmed. I did not notice as I use fixed output volume (78% in my case to mitigate EQ gain to keep output meter below 0dBFS) and adjust listening volume on the analog side, for maximum use of DAC resolution (if only I would be able to hear a difference, just for principle ...)
When using variable output volume and the original signal meter, it makes mad jumps when the hardware volume knob is turned, and if the volume knob is set to 0%, the input signal goes to 0, too. There's room for improvement ...
