WiiM Ultra Firmware v5.2.730566 Update - Sep 26, 2025
5.2.730566 (In Progress)
Release date:
9 / 26 / 2025
What's New:
  1. Smarter VU Meter – More accurate readout of your output levels.
  2. Amazon Music – Faster resume after long pauses and improved casting stability from the Amazon Music app.
Bug Fixes:
  1. Dolby Audio – Eliminated playback noise and fixed subwoofer no-sound cases.
  2. USB Library – Refined image resizing for crisper album art.
  3. Pandora – Resolved track skipping after resume and login failures.
  4. Alarms – Station-based alarms now trigger reliably.
  5. TuneIn – Apple Music radio via TuneIn now resumes after long pauses; reduced radio playback failures.
  6. LMS – Correct bitrate display for radio streams.
  7. KKBOX – Fixed playback interruptions and corrected bitrate reporting.
  8. General – Stability, performance, and other minor fixes.
saw the led flashing. after opening the app this childish rocket appeared. what is new and i could start immediately. so accomplished fact. but no problem. as long as qobuz works it is all good.
I got it too ... sadly the covers in the usb media library still looks pixelated. Doesn't matter which resolution I upload.
Edit: only in the smaller cover view - when full screen it looks fine now. Must be something with the scaling ... but for sure not that important.cover.jpg
is it normal that after a firmware updates all services in the browser section are set to active? no big deal. but wasting at least five seconds of life time 😉
No, that should not happen unless it was a factory reset.
Mine updated without changing any configurations.
@hgo58 do you also feel the 0dB full-scale approaching? :LOL:
Interestingly the VU meter scale changes between the input (original ) signal and the output signal.
This is input (-25 to +3 dB):
And this is output (-60 to +10 dB):
Why? It makes no sense to me.
I guess that this is what was clearly requested by many - while scale of -25 to +3 is perfectly fine for input source (and offers quite nice display "dynamics"), for output volume it led to the situation that when the signal was attenuated to say 50% the needle did not move at all (as it was sort of "below" -25). I think it is ok now?
And where is the max signal value (0 dBFS) then?
0 dB, +3 dB or +10 dB?
I cannot use those scales for anything. It's just a needle moving.
No idea:) - I just use it to see (from afar) if something is playing (or not). And its look is quite pleasing to me - brings some life to the display:). So it works perfectly fine for me, however I fully understand that it might not be sufficient for more serious use.
Although 0dBFS really should be max value, there should be an indicator (a red led on a screen corner) that would light (and maybe some small delay before turn of again). This can happen due to inter-sample peaks, caused by digitally sampled points that can become higher than the sampled peak during digital-to-analog conversion, causing distortion, or even the use of +dB on PEQ / RoomFit.
For the Output Signal this would be awesome to become aware if some signal processing or the music files themselves are causing distortion.
In my case is not that probable since all my files have ReplayGain applied according to EBU R128 and with True Peak Scan enabled. This gives a good headroom to avoid clipping, but... one never knows.
That is fine. I'm just expecting a little more than a toy. Especially because it is easy to do.
WiiM could keep the graphic and just define the scale to match dBFS with the 0 dBFS at the current +10 (+3).
the needle is fine..for your use this can be more explicit...
