WiiM Ultra Firmware v5.2.730566 Update - Sep 26, 2025
5.2.730566 (In Progress)
Release date:
9 / 26 / 2025
What's New:
  1. Smarter VU Meter – More accurate readout of your output levels.
  2. Amazon Music – Faster resume after long pauses and improved casting stability from the Amazon Music app.
Bug Fixes:
  1. Dolby Audio – Eliminated playback noise and fixed subwoofer no-sound cases.
  2. USB Library – Refined image resizing for crisper album art.
  3. Pandora – Resolved track skipping after resume and login failures.
  4. Alarms – Station-based alarms now trigger reliably.
  5. TuneIn – Apple Music radio via TuneIn now resumes after long pauses; reduced radio playback failures.
  6. LMS – Correct bitrate display for radio streams.
  7. KKBOX – Fixed playback interruptions and corrected bitrate reporting.
  8. General – Stability, performance, and other minor fixes.
That doesn't make any sense and you are mixing up dB and dBFS.
It makes perfect sense and you don't understand that by using higher number formats internally, for exmaple 32bit numbers, digital audio processing devices can go significantly over 0dBFS defined by the max level of the 24bit DAC, for example.
Please check my tutorial here:
Yes using a 32 bit floating point format for the audio processing, the signal can temporarily exceed 0 dBFS (the maximum level of the 24-bit) without clipping but I don't think the VU meter shows that. On the output we look at the 24 bit format and the same on the input.
I don't think so.
We are looking at the internal number format of the digital signal processing of the WiiM, whatever it may be, and nothing else is available for a digital display meter, with the zero full scale dB reference defined by the ADC or DAC reference max level.
(Edit: Leaving for today, just missed the 3:0 AND 4:0 for FC Bayern while typing ...)
