telecastermds`
- Oct 25, 2022
Yeah, if it had the black front like the IOM amp that would be
If you only had a Mini or a Pro/Plus and wanted an amp that had a better DAC (which I guess this'll have), the vibelink could be a good fit...
Why isn’t it an add-on power stage for any WiiM Streamer? While it has multiple inputs, I don’t think the intention is to use more than one at any one time, it’s just to give a choice to existing streamer owners. If you have an Ultra, use the analogue input. If not, use a digital input from your mini/pro/plus and get access to a potentially better DAC in the vibelink. If it only had a single analogue input, I’d feel disadvantaged if I didn’t have an Ultra…
I think you may be over thinking it![]()
Nobody ever hinted at a price tag of GBP 400, though.4 - The WiiM costs a lot more than the Topping. At the moment it's twice as much, and even if the price drops from £400 to £300, that's 50% more than the Topping.![]()
That's just fine, it's a power amp with some goodies, not an integrated amp.If you leave the amp at full and control volume from the Ultra, you've limited the digital input on the Vibe to a source with its own volume control (or you'd be blowing your head off), so that's already only useful to what, 50% of users?
Nobody ever hinted at a price tag of GBP 400, though.![]()
Out of curiosity, why do you term it not an integrated amp?Nobody ever hinted at a price tag of GBP 400, though.
So $400 not £400Oh yes they did.
They said $400 USA and £300-and-bits UK. Only previous price announcements have been 1:1 or more.
That might not be a fact. But it’s at least a hint, and probably more.
How can you say "Oh yes they did" and then without further ado reduce your claim from GBP 400 to GBP 300?Oh yes they did.
Pretty much every PA power amp ever made has a volume control. Many have different input connectors. That doesn't make them integrated amps, of course.Out of curiosity, why do you term it not an integrated amp?
I was under the impression that an integrated amp is any amplifier with volume control.
Wait…so there’s no remote?! What was that remote for at the Bristol show when they previewed it?How can you say "Oh yes they did" and then without further ado reduce your claim from GBP 400 to GBP 300?![]()
That doesn't work out. Your Topping iss getting more and more expensive by comparison.
Traditionally, an integrated amplifier was the combination of a pre-amp and a power amp in one case. Back then, the pre-amp actually had to pre-amplify the signal, in particular that of a turntable, of course. FM radio inputs often needed higher amplification than e.g. tape recorders. And of course, at least one tape out connector and monitor switch(es) were the norm.
That definition is no longer helpful, obviously. But we have other hints regardiz the intended use: No remote, no sub out, only one analogue input, no network connectivity, no app control ... by all means, this device is definitely not intended as a modern day integrated amplifier.
Not everyone has to have use for it. I just don't get this "if I don't need it, there's no market for it" attitude.![]()
No idea. Might be a separate product.Wait…so there’s no remote?! What was that remote for at the Bristol show when they previewed it?
That is probably a 2nd gen remote that connects to and controls a WiiM streamer, not sure yet if it will be included with Vibelink, but my guess is not. (I don't know if the remote will be released on its own or if it will be replaced in the future by a 1st gen remote).Wait…so there’s no remote?! What was that remote for at the Bristol show when they previewed it?
-Ed
What are you on about? There is no such difference between integrated amplifiers or power amps with volume control. A classic integrated amplifier has a preamp section for volume control (and sometimes EQ) which is applied directly at the input signals, in front of the actual amplifier circuit.No, not the same. The volume on an integrated amp controls the output volume, whereas on a proper power amp, the gain control adjusts the level of the input.
Maybe you like the dual tpa3251 ( used in 3e audio A5 ) better than Fosi:s tpa3255 ?telemike agrees with you.
The SINAD figures might have to be taken with a grain of salt. But the fact that Amir had a ground loop issue with his AP analyser is not helpful, at least.
I must admit that I enjoy my 3e Audio A5 more than my V3 Monos. That's my bashful way of saying that I thinks that there's a difference in sound quality, when objectively many would declare the differences as beyond the threshold of perceivability. That puts me in a camp I'm usually not associated with.Consequentially, I might be willing to lend the WiiM Vibelink Amp my ear (or both of them) before coming to a final judgement.
The nice looks and the comfort of an integrated power supply surely make it attractive, at least to me.
the behavior of the 3a in the asr measurements is clearly more classic, less temperamental when faced with the load at the end of the band compared to other machines in this amp family...telemike agrees with you.
