🎉 Introducing the Vibelink Amp – Unleash the Power of Pure Sound 🎉
AD_4nXfvs54s98UfOTSBRzVSpxvPmRNbLlec-p99r5CenPY_874SCawk4vc3Uzos3r1a2uL0PK8pk5TuYmRp_4cfRsYaXP397YIU0nIUO4s1Hv2OtB-_oFK5aUat6rrlSmffBQpmd4iSeA
Hello WiiM community! We’re thrilled to announce the launch of our latest innovation: the Vibelink Amp! Designed with your needs in mind, this 100W per channel amplifier brings high-fidelity sound and unmatched versatility to your audio setup. Perfect for passive speakers, the Vibelink Amp ensures a premium listening experience when paired with one of our streamers, with a footprint designed to match the WiiM Ultra. By leveraging its premium DAC, Vibelink Amp is also a perfect match for WiiM Mini and WiiM Pro or WiiM Pro Plus via digital input for superior sound quality.
🔊 Why Choose the Vibelink Amp?​
  • 100W per channel at 8 ohms, 200W at 4 ohms: Experience powerful, distortion-free amplification for room-filling sound.
  • Premium unibody aluminum design: Sleek, durable, and thermally optimized for efficient heat dissipation during prolonged use.
  • High-fidelity audio with premium components: Premium DAC, amplifier, and op-amps
  • Post filter feedback technology (PFFB): Overcomes speaker's load-dependency
  • Bit-perfect playback (192kHz/24-bit): Achieve true audiophile performance with every note.
  • Anti-Pop Noise Design: Enjoy smooth transitions across variable sample rates and bit depths without interruptions.
  • Auto Standby & 12V Trigger In: Smart energy-saving features that fit modern setups.
  • Pure analog input (no ADC conversion): Savor uncompromised sound quality for your favorite analog devices.
  • Seamless integration with WiiM streamers: Effortlessly pairs with devices like the Ultra, Pro Plus, Pro, and Mini for high-resolution audio.
AD_4nXerpxGcnsbPzviuW6WVqqD84_9tcB-xETgegIXIzTr5kQ6aH8D77U8fX7dhW5VXRP-Gn5fpnJi6pMMdrE4JAuMzcx0DkcB91WjMb5CI4UyM5m6hn_88qFitnvknMJMIsYMUhkWyoA
🔍 Key Features You’ll Love:​
  • Hi-Res Audio Excellence: Packed with a high-quality built-in DAC ESS ES9039Q2M, one TI PCM9211 digital and analog front end, six TI OPA1612 Op-amps, and a TI TPA3255 Amp Chip, the Vibelink Amp supports up to 24-bit/192kHz high-res music allows you to optimize beloved, decades-old, high-quality audio systems or connect current speakers with your favorite platforms effortlessly.
  • Versatile Connectivity: Easily connect your favorite devices with analog (RCA) or digital (optical, coaxial) inputs.
  • Compact & Efficient: With a sleek, stackable design and cutting-edge thermal management, the Vibelink Amp fits right into your setup and stays cool even during marathon listening sessions.
  • Easy, Secure Connections: Standard stereo banana plug output ensures a solid connection to speakers, delivering high-quality sound without signal loss or dropouts.
AD_4nXfvSY4zCVEzcvdUWiyMg28Z9MlQSUGM9gYgLggqYRTnAYkrlfZ6LxlEEcvie9rqSADieUM5y43PT8ktAlF5ylfIZXNcnfvKC8uVwLPO7pj_qirUsHlg_0GNfXW3QRm8Zo776U0o
Why We’re Excited:
1️⃣ Compact Yet Powerful – A well-built, high-performance amplifier that delivers exceptional power in a sleek, space-saving design.
2️⃣ True Hi-Res Audio Support – Supports up to 192kHz/24-bit, ensuring full compatibility with high-resolution music services and user libraries, unlike many amplifiers that lack this capability.
3️⃣ Seamless Playback with No Artifacts – Effortlessly handles variable sample rates and bit depths between tracks, eliminating unwanted pops and clicks that occur in many amplifiers when audio resolution changes.
At WiiM, we’re all about listening to our community. Many of you asked for a powerful amplifier that delivers exceptional sound quality and integrates effortlessly into existing setups and we’ve been listening! The Vibelink Amp is a dedicated solution for passive speakers, designed to pair seamlessly with all WiiM streamers or as a standalone amp for your favorite gear. Whatever your setup, this amp brings the exceptional sound quality you’ve come to expect from WiiM.
The Perfect Match for WiiM Streamers​
✔ Seamless Integration – Designed for flawless compatibility with WiiM Mini, Pro, Pro Plus, and Ultra—just plug and play.
✔ Flexible Connectivity – Choose digital (Optical/Coaxial) or analog (RCA) inputs for maximum audio fidelity.
✔ Ultra-Low Latency – Perfectly synced playback for high-resolution streaming and immersive home theater sound.
✔ Studio-Grade Sound – Experience deep bass, crisp highs, and stunning clarity with bit-perfect precision.
Pair your WiiM Mini, Pro, Pro Plus, or Ultra with the WiiM Vibelink Amp and experience pure, powerful, and immersive sound like never before. Elevate your high-fidelity streaming with crystal-clear detail, deep bass, and room-filling audio.
🎶 Your music, perfected. Upgrade your setup today!
Pricing and Availability​
The Vibelink Amp will be available starting March 18th on Amazon US for $299, with international availability on its way. Don’t miss your chance to elevate your audio experience! Find out more on our website.
Let us know what excites you most about the Vibelink Amp, and share your setups! We can’t wait to hear your thoughts! 🌟
For fidelity you need to control volume from a lossless volume control . Wiim ultra volume is not lossless so it makes sense to use the volume control of vibelink amp or your integrated amp
I understood WiiM devices’ digital volume control was performed with no loss in precision viz.
https://forum.wiimhome.com/threads/...mprove-digital-volume-control.3063/post-47075
Plus, what if you have a sub connected to the Ultra? Surely you wouldn’t control the volume at the vibelink in that case?
Using an analogue volume control brings its own issues.
And, of course, using the Vibe’s volume is a non-starter if you have a sub attached to the Ultra.
Very interesting discussion, but no one has listened to it, correct?
The Ultra has a very good volume control. I’m willing to bet that you cannot hear it doing anything else than it’s task.
"But wait! Did anyone notice the WiiM subwoofer on the floor at the Bristol show? I think most people missed it. This raises the most obvious of questions: why would WiiM make a subwoofer when it doesn’t make streaming active loudspeakers? "
The answer, no doubt, will come at Munich High-End 2025."
That's like saying "did anyone notice the remote" it was there but the vibelink has no remote
pointed out for a long time... wiim could in partnership with a serious subwoofer manufacturer, produce a subwoofer simply using their connectivity... mini " insinde".. dsp peq, or fonction from ultra etc
easy...
I think it would be better if you set the volume of Ultra to 100%, then gradually increase the volume of Vibelink to the maximum volume for you, and then fix the volume of Vibelink.
I agree to this method. This is consistent with the best practice to set the gain structure for pro audio. What's unknown is a gain factor of the Vibelink. I speculate Vibelink's input gain is optimized for Ultra's maximum output voltage.
So this is basically a stereo integrated amp & DAC? Does it have a Wiim streamer built in?
