- Mar 2, 2024
Has anybody managed to get it to work yet?
Have you tried local content?Has anybody managed to get it to work yet?
So you wanted wiim to cap it at 256kbps?Think I was a bit irritated because WiiM offered it as kind of substitution for the Apple issue. Or did I understood it wrong?
Anyway just got out of beta back to stable.
Because a never expected love for Apple Music made its way into my head I really think about a DMP A8 instead of the Ultra. Needs some more research..
Yes, I have tried local content, and can play content via DLNA effortlessly from a Windows mini PC.Have you tried local content?
Do your speakers support 24/48?
I think the stream gets transcoded so it probably doesn't make much difference what the input is.Via the WiiM Home App, the best I can manage is an occasional stutter of about 1-2 seconds of sound, every 5-10 seconds or so, and that was using a 320kbps, 16 bit, 44.1 KHz stream.
I'm using iOS, and my WiiM devices are all connected to a mesh WiFi network. I have tried with WiiM Pro, and WiiM Pro Plus devices, and achieved the same results.I think the stream gets transcoded so it probably doesn't make much difference what the input is.
I've been successful with Sonos and Ropieee so far.. If you're on Android you could try BubbleUPnP. Enable the Local renderer and 'Allow remote control' to see if that works for you, as it does for me, after an initial delay.
Is your WiiM wired or using WiFi?
Given the WiiM not only needs to receive the file/audio from your media server but also send it out to your DLNA speakers, would it be possible to rule out Wi-FI by moving one of your WiiMs to a router (given it doesn't need to be near speakers for this test) and using that to DLNA cast?I'm using iOS, and my WiiM devices are all connected to a mesh WiFi network. I have tried with WiiM Pro, and WiiM Pro Plus devices, and achieved the same results.
It's a second FW with DLNA cast? I didn't get any yet.My Pro Plus just updated its firmware to 4.8.620750, with no info on the rocket popup. It’s no longer marked as beta in device settings, but the DLNA cast option is still there…
I’ll go try some of my tests again…
Yeah, looks like it. I applied thru the link here, maybe twice as I thought it was slow coming. Maybe apply here againIt's a second FW with DLNA cast? I didn't get any yet.
I've had Sonos Play:1s work and the local renderer in BubbleUPnP, but no luck (no audio) with RoPieee or Chromecast proxied renderers.None appear to work though and I'm not seeing my RPi renderers in the list
