Ongoing Beta Beta Test: Simultaneous USB out and Sub out
More helpful to the community if you submitted a bug report if indeed prior behaviour has changed
I created a ticket and wait for answer. Its not a bug at least. Its more a change to a new feature. So maybe I'm the only one with such an issue and nobody else need something like myself. So I can stick to an older firmware. I don't mind. Lets see, what the support is responding.
You aren't the only one. I also (rarely) use headphones with a USB interface and wouldn't want the sub enabled.
It has been requested before to automatically disable Sub when headphone is selected as output.
This was however rejected by some, as they want to "feel" the bass ever when using headphones.
Understandable, then just make it individual adjustable for sub-out. If sub out is on: then for ..... shall be implemented in the sub out settings.
Currently it is working with my wiim Ultra. But I have a issue with it. I use for USB out a headphone DAC/Amp and so sub out is somehow annoying, because I need to turn off 'Sub out' when I'm on USB out and turn on again, if I would like to hear sound via my speakers which are connected on line out.
Is there an option to turn off Sub out, when I switch to USB out? That would be really appreciated if I'm able to adjust when sub out should be enabled (all but not USB out).
In your case use smart plug to turn on and off whenever you want it.
If you mean for the subwoofer you still need to disable the subwoofer in the app or the crossover will be active.
True but that can be done easily on app plus you won’t get up to turn off sub since smartplug has app you can control. It’s not ideal solution but there’s no other choice. We can’t be lazy to turn off the toggle isn’t it? 😆
Exactly. I need to connect the sub to the speaker itself. That would work, but then I lose all very nice settings for the sub.
