You don't need to sign up for Beta again; we will deliver the new version to you.Do we need to sign up to Beta again or is this auto sent to those already registered? Thanks!
Thanks- I need to find some FLAC 192 tracks to test with@BigJusDXB
It looks as if you listen to MQA = Master files with the WiiM doing only the first unfold!
So strange for me. Even playing your example John Coltrane track through Tidal Connect, it is limited to 96Khz, as per my DAC display.The example I have posted in above is such example. Even if it is likely not everyone's taste
The Tidal app shows and plays it in 192/24 flac.*
Tidal connect plays it with obviously a few stuttering issues which should be solved with a new firmware as WiiM posted.
Tidal integrated in WiiM home shows only Master MQA files and not FLAC as far as I've noticed.
*Edit: Both Android and iPad OS
If you signed up but don't yet have it, try raising a ticket to WiiM thru the feedback section in the WiiM Home App in case they haven't registered your requestWhen will my Wiim be updated to Beta Test?
OK I'm waiting too...You don't need to sign up for Beta again; we will deliver the new version to you.
The second one. WiiM app is not yet updated to play hi-res flac but can shows what is passing through.When I play tidal though the Wiim android app (no tidal connect) the screen shows 24bit/96. (wiim pro plus)
When I play with tidal connect via my tidal windows app my android wimm app (which is not playing but just syncing) shows 24/192!!!
Which one is correct!!!!!!
What is the firmware number?????With the just arrived new beta FW, stuttering disappeared.
Now, all 192khz streams are correct, eve those over 6000Kbit/sec.
4.6.532942 on miniWhat is the firmware number?????
Of that’s the case, public release won’t be far of.With the just arrived new beta FW, stuttering disappeared.
Now, all 192khz streams are correct, even those over 6000Kbit/sec.
Works great now, no more stuttering.We have released a new beta firmware for WiiM, which solved the stuttering playback issue. Please try it again.
Hi, if you're interested in beta testing Tidal Hi-Res please fill out this form. We'll OTA the beta firmware next week.
Beta Test: TIDAL Hi-Res (i.e. Max)
We're looking for TIDAL users who would be interested in beta testing TIDAL Hi-Res for both TIDAL Connect and in-app version in our WiiM App. If you're interested please provide your information below and we'll OTA the beta firmware sometime next week.docs.google.com
