Yes, but that's not necessarily the thickest part of the plug. It's just a little hard to see.There is a gap between them. Zoom in and the letter U is visible.
I tried to make two attempts but the left side always remains behind, however everything works perfectly, so I don't touch anything anymore!The plugs are not blocking each other, are they? If you plug in the left one first it still sticks out a little?
Great cables, great RCA connectors.The Neutrik Rean RCA connectors are a breeze to work with, also on the Ultra, making a proper connection without excessive force.
My Cordial CFU CC rca cables which are made the way an RCA cable should with a single conductor plus shield, use those. They come in pairs in 0.6, 0.9, 1,5, 3 and 6 m lengths, black or white cables and connectors.
Thomann distribute world wide.
Sorry to hear that! I hope WiiM stops using those deep-mounted connectors on the next streamer, so that no such things happen anymore. Too many needs to use force to get their 3rd party cables..Changed the cables connected to my Ulta RCA out. On powering up I had a massive buzzing sound. I think both channels Turned everything off and checked connections. It appears that ground on the ultra has separated from the pcb on both channels
Good tip, but it should’nt be necessary to buy new cables.Repeating myself:
Do not destroy your Wiim product with unsuitable connectors.
The WiiM Ultra comes with fitting cables. You don't have to buy new ones.Good tip, but it should’nt be necessary to buy new cables.
Many years ago I bought a recommended RCA cable from Tandy or Laskys and it was so tight it pulled off the outer part of my amplifier RCA sockets when I tried to remove it.The WiiM Ultra comes with fitting cables. You don't have to buy new ones.
I still don't see how plugs that don't mechanically fit the case recess could destroy the (admittedly cheap PCB mounted) RCA sockets. Either they fit sufficiently to make contact (in that case it's just a matter of how much force you apply plugging them in) or they don't fit (in which case it should be impossible to push them in too far).![]()
Testing the fitment of the male connector with the female end of another cable might prevent this or other similar damage.Many years ago I bought a recommended RCA cable from Tandy or Laskys and it was so tight it pulled off the outer part of my amplifier RCA sockets when I tried to remove it.
Female cable ends aren't common though.Testing the fitment of the male connector with the female end of another cable might prevent this or other similar damage.
If that's true, I have a box of old cables that proves I'm the exception rather than the rule. Not the first time or circumstance.Female cable ends aren't common though.
Somewhere I have an adapter cable RCA to 3.5mm which has female sockets, no idea where it is though.If that's true, I have a box of old cables that proves I'm the exception rather than the rule. Not the first time or circumstance.
As shown in this thread not all male RCA connectors are sensibly made. I have some overly tight ones in my cable cardboard box of shame.Good tip, but it should’nt be necessary to buy new cables.
What is evident to me in this thread is that close tolerances are not always respected. If undue force is required to make a connection caution is indicated but not necessarily exercised.As shown in this thread not all male RCA connectors are sensibly made. I have some overly tight ones in my cable cardboard box of shame.
(RCA is a pretty bad connector standard, but it’s what we have in hifi. It migrated from the USA to Japan and thereafter swamped the European DIN standard. It’s what sells most that wins.)
+1 for Cordial. My go to brand for cables for the studio and hifi setup.Repeating myself:
