There’s no indication that it does, nor does it ask for calibration data like HouseCurve does.Does RC from iOS support external mic on its current status?
It is much cheaper to just borrow an iPhone from a friend for the initial room correction setup. As the calculated PEQ values will be stored on the device, you can afterwards use the room correction settings when playing music from your Android phone.Hi @WiiM Team,
It would be great to understand whether you are working on enabling the use of a external USB-C mic for Android users. If this is the case and if you're already working with a given mic, we could already purchase it and start doing some room correction tests with e.g. REW in order to have a benchmark to compare with WiiM's RC performance.
I do not feel like buying a microphone now that will not be compatible with WiiM software in the future.
Thanks!
In the REW measurement tutorial by Julian Krause (https://www.youtube.com/watch?v=Ev1bSSL8tRA) you calibrate sound levels to 75db with a noise sample before making measurements (it is quite loud and not applicable in the night). I would try to replicate that before doing the room correction measurements with the WiiM app.Latest version using app 2.9.7 is considerably better than last weeks. Out the box you get a much better sound far less muffled (IOS) however I’ll do more testing tomorrow. I’m facing issues with the Wife complaining about the noise each time I do a test so testing is on hold for the evening. One thing that would be useful is being able to gauge what kind of volume levels should be used. Different levels give different results. Decided to test using ‘normal’ listening comfortable listening levels.
As an Android user, I guess we may end up requiring a external calibrated mic to do the job. I doubt there is a good way of getting standardized measurements with the huge variety of mics and implementations in Android devices. DA IMM-6c, for example, is cheap enough for the task and I would not need a friend to be around everytime I want to play with RC.It is much cheaper to just borrow an iPhone from a friend for the initial room correction setup. As the calculated PEQ values will be stored on the device, you can afterwards use the room correction settings when playing music from your Android phone.
It's a workaround, kind of acceptable at best. It would leave us where other (more upmarket, admittedly) manufacturers have been about 8 years ago.It is much cheaper to just borrow an iPhone from a friend for the initial room correction setup. As the calculated PEQ values will be stored on the device, you can afterwards use the room correction settings when playing music from your Android phone.
I guess the only solution will be that WiiM will have to provide a cheap but usable microphone for RC with the device. One way could be to incorporate a sufficiently good and standardized microphone into the remote.I'm confident that WiiM will add a better solution for the tinkering Android crowd in the future.
They could also be supporting 3rd party mics (should be relatively easy with USB mics) and the upload of calibrations files.I guess the only solution will be that WiiM will have to provide a cheap but usable microphone for RC with the device. One way could be to incorporate a sufficiently good and standardized microphone into the remote.
Same here. Greetings from Cologne.I will sit back and wait and use REW and my UMIK-1 for now.
I got no friends...It is much cheaper to just borrow an iPhone from a friend for the initial room correction setup. As the calculated PEQ values will be stored on the device, you can afterwards use the room correction settings when playing music from your Android phone.
Something like this might let you use the UMIK-1 with your phone.They could also be supporting 3rd party mics (should be relatively easy with USB mics) and the upload of calibrations files.
Well, possibly. But only if WiiM starts supporting USB mics at all on the Android platform.Something like this might let you use the UMIK-1 with your phone.
Even if WiiM do support Room Correction on Android I am not sure what benefit it will bring over REW.Well, possibly. But only if WiiM starts supporting USB mics at all on the Android platform.
Using any 3rd party measuring software on my phone would not really be beneficial if I can use the fully featured and fully trusted REW suite on my computer. Setting the PEQ filters is a manual process in both cases.
REW is not precisely user friendly (GUI is really poor). Another benefit is automatic EQ profiles based on the room measurement with the click of a button. I think this is a huge advantage for many users.Even if WiiM do support Room Correction on Android I am not sure what benefit it will bring over REW.
I don't agree at all.... GUI is really poor ...
