this presents correctly on the peq side( l/r now? ;-) ) but still remains this old subject, the appreciation of the general level to be applied to avoid saturations...I've played some test files using the same PEQ settings as before, for Roon vs internal WiiM DSP. Unfortunately my PC had crashed so I cannot provide any graphs from REW. I will repeat it when I'm back from the hospital. All I can say is that both processing paths deliver very similar results, so WiiM 10 band PEQ seems to be well designed.
I was able to compare results for a real audio file, differences were analyzed in DeltaWave. Results of PK metric indicate that it's very unlikely to distinguish audible differences between both processing paths.
That's all for now, guys. You can wish me good luck, I would really appreciate it.
We don't have L/R PEQ yet. It should be available on 15th Junethis presents correctly on the peq side( l/r now? ;-) ) but still remains this old subject, the appreciation of the general level to be applied to avoid saturations...
much more difficult to learn in peq than in eq mode...
cross fingers too ,we'll talk about it when you get back ;-)
I wish you well and hope you will be better soon.I've played some test files using the same PEQ settings as before, for Roon vs internal WiiM DSP. Unfortunately my PC had crashed so I cannot provide any graphs from REW. I will repeat it when I'm back from the hospital. All I can say is that both processing paths deliver very similar results, so WiiM 10 band PEQ seems to be well designed.
@onlyoneme, count me in on this comprehensive listing of get well soon wishes.Best of luck, thoughts, prayers, good vibes, aligned chakras, and various levels of psychic energy flooding your way through the ether.
All the best. Get mended soon.
Best wishes and speedy recovery - try not to over analyse the graphs on the medical instruments you’ll have round youI will try to pass some test signals and also real audio to compare results using this setup, before I go to the hospital.
No chance, some of them will hypnotize meBest wishes and speedy recovery - try not to over analyse the graphs on the medical instruments you’ll have round you![]()
There is one scar already so the correct side is markedDon't forget to take a pen and correctly mark the area that needs to be operated on! There are some left-handed surgeons, and there won't be anyone to tell them "not THAT right, the OTHER right" (disclaimer: my wife is left-handed and she keeps mixing left and right, as well as up and down).
Be sure to eat (assuming the hospital fare is edible). Quickest path to recovery: eat like Goku. And good luck!They mark how the cut will be made during the last medical rounds (not sure if it's correct phrase) before the surgery.
As long as your body measures well everything is fine! Take care.Purely off topic, but I have to say wholeheartedly thank you to all of you guys, as I'm just going home from the hospital. More measurements will come![]()
