TV display
Steve Woodhouse
I know I’m flogging a dead horse, but really, if you could just introduce this.
Go to the video below, 1:14 to 1:49.
The image on the TV at 1:40, just give us that please.
Not everyone will either want it use it, but there are surely enough of us who’ll will to make it worthwhile.
Thank you.
Upvote 2
I do hope it's that simple.
I'm waiting for henninggodske to share his method of getting the wiim player to cast directly to a tv.
Never said that I can do that. It's just a suggestion that WiiM team may take up.
Maybe some of the projects running on Linux could be a starter for this if they were shared with the WiiM team?
Awww man...
I thought you were suggesting I try this.
Do these WiiM streamers use an OS? Can apps be side-loaded into memory like one does with a Firestick?
Can I look forward to future hacks of these boxes to open up amazing new potentials?
Yes. WiiM devices uses Linux. Probably in a dedicated imbedded version.
No, there is no way to side load applications (except for the developers, I guess).
If software based I do hope it can be configured within the WiiM device settings (pref per source channel).
The cast from WiiM home app would not easily cover Spotify Connect from Spotify app without doing a multi-app dance...
Also using bi-directional HDMI would disallow setup of a separate "dedicated music display" if the user wants to have TV ARC as well.
Allwinner Tina Linux from memory…
Indeed, it’s not like Android…
Except that android is a derivative of Linux 😋. Quite a few android programs can use cast (usually audio), so In principle a video cast feature should be possible, but I've no idea how complex this could be. Roon has a remote display feature, but I don't know how they implement it. It certainly would be a nice feature for Wiims.
I would prefer a cast function, but until then I am using this method:
img_5615-jpeg.1048190
So far, I've tried miracast WHA to Android tv & LMS browser (material) to fire tv. The Firefox Silk browser is the better of the two (allows on screen management with the fire tv remote). The only snag I've seen is that without some remote interaction, the fire tv goes to screensaver after a while.
I can't find a setting to turn the screensaver off completely (a fire tv hassle).
Right. I've already done what's suggested - so I'm now thinking that it's the Samsung TV screensaver which is kicking in. Now where did I put the Samsung remote 😁🤔?
This is a little web server program (wiim-now-playing) that I've been using for the past month.
Point your browser at the server (Raspberry Pi, NUC, whatever). It continuously tells you what is playing with album cover art. It only has pause/play and previous/next track controls, so simple actions on whatever stream or folder you're playing. It can easily be run in parallel with LMS or whatever you use. Mostly I use this on a second monitor while working, but you could point a browser from a TV if that suits you.
I optimized this for my TV screen.
Deleted some stuff that wasn't needed for TV screen use and edited the layout and style to my liking.
Really happy with the result.
Works fine. You just need an Apple TV or a tv that is able to accept AirPlay. The WiiM home app will still control the ultra but the picture will be displayed on your tv.
Hi! Would you mind step by step showing how you did this? I have an AppleTV 4K and an Ultra on same network. Can’t figure this out lol. Thanks in advance
I definitely plan to do that but I need to clean up the code and undo some changes first. For example, I changed the logo for the DLNA stream to the plex logo since I only use it for my plex server.
Whilst I’m sure you’re a genius, etc., here’s what gets me. If you can do it (and no offence intended), then (a) there’s no question that it can be done and (b) surely WiiM must have the know-how.
Thanks for all your efforts and information.
Ha no offence taken. It really was more of a trial and error thing until it looked like I wanted it to. The main work was done by the creator of the original.
