DryTortuga
Senior Member
My understanding is native squeezelite support is required for proper sync across players using LMS.
That is very true. Although the WiiM runs with default settings the 3 bridge plugins are, let’s say, a little counter intuitive.Native support would also mean one less thing (the plug-in) for normal mortals to deal with. The LMS server has been the only server solution that happily deals with my 5,000 single file flac/cue rips. Can’t do it with Roon.
I notice the page does have a section for usb drives (just had a quick read and not sure if the instructions were to access existing media on that drive or reformat it for LMS use).
The Roku soundbridge! Never had one but always wished I had.On the picoreplayer LMS tab you can install file system support for FAT, NTFS, and separately exFAT. Works great for me with a 2TB SSD on the pi 4 USB 3 port. I use exFAT to sneakernet the SSD to my main music archive on a Mac when I want to add a new rip. Quicker than Samba network copies. Add the file systems and mount the USB drive BEFORE you install LMS. LMS will also run well on older Windows, Mac, and Linux boxes. I was running LMS for years on a 2009 Mac mini with Linux. For you young pups that wonder what streaming was like in the “old days” check out the LMS history of Logitech Squeezebox, Slimp3, and even the original Roku product. They’re all in my closet of historical significance next to my TRS-80.![]()
@d6jg are you still getting gapless playback using UPnP/DLNA bridge. I have tried with both the 2.1.1 version and the newest dev version and I still get a gap between gapless tracks. I have used the same settings as you show on the LMS forums. Other than that everything else is working.Success.
Confirmed - WiiM Mini with latest dev UPnP/DLNA bridge 2.1.1 for LMS allows gapless without any transcoding or flow involved i.e. out of the box settings. The bridge also passes metadata and cover art successfully.
I'm not sure where it got broken then fixed as there have been many changes to the plugin in last week or so but I have played some 24/96 stuff from Qobuz, some Radio Paradise (FLAC) and listened to a local 16/44.1 rip of DSOTM all via my LMS server and all work.
I'd say that the WiiM Mini is 98% compatible with LMS out of the box in this pass through mode - it still misses replaygain and crossfade so I can't say its 100%. My testing is via Optical out to an external DAC. I still can't say that the onboard DAC is anything other than OK. However, as this is so close to being a perfect LMS player when used with an external DAC I'd encourage anyone who currently uses their WiiM with a UPnP server to try it with LMS. The LMS ecosystem is so much better than any UPnP server I have ever tried (and there have been many) and there is a very active community forum at https://forums.slimdevices.com/ where lots of help is at hand.
Squeezelite on board would make it a game changer for the LMS community (who probably outnumber the Roon community) so come on WiiM get it done!
My WiiM Mini is located in my office and I won’t be going there until tomorrow (Fri). Last time I played DSOTM I’m sure it played correctly but I’ll play it again tomorrow and confirm.@d6jg are you still getting gapless playback using UPnP/DLNA bridge. I have tried with both the 2.1.1 version and the newest dev version and I still get a gap between gapless tracks. I have used the same settings as you show on the LMS forums. Other than that everything else is working.
